Anyone ever used the Fuel Injector Clinic 2150cc
Im not sure which injectors to get I am stuck between the ID2000's and the FIC2150cc's any have experience with both? I am looking to make between 750-850whp
Re: Anyone ever used the Fuel Injector Clinic 2150cc
Im looking at running e85 and want to make that power goal, I know the ID2000 will make the lower end but do they flow enough to make 850?
We use ID2000's and soon another set of ID1000's on our race car. However I am curious is too what the difference is, I know the DP Performnace guys are running them. I'm sure Tony will chim in... Isn't the FIC a denso injector? Or?
the id2000s can go up farther if you have an adjustable regulator so it shouldnt be a problem making 850 on e85
they will but IDs are still very controllable at very high fuel pressures
i also beleave the FIC are only flow matched but not pulssewidth or dead timed matched like the IDs so they wont idle or drive "stock" like
from past experiences with big injectors before ID came along cars would run grate WOT but for part throttle they were eather to lean or to rich one increase in fuel would move the AFR from 17.0.1 to 9.0.1 there was no in between unless your on something like motec were you can adjust individual dead times and offsets
We run FIC 2150's in our Supra, love them - its the exact same injector body as the ID2000 - if you have any questions about them PM me
Matt
I've used both the Id2000 and the Fic 2150, both work great, they are the same thing in my eyes. The fic 2150's are the same unmodified bosch injector that Id uses for their id2000.
To the Op, what fuel do you plan on running??
I run there 2150's on my secondaries and work great haven't had one issue. Also just switch my primaries to there 900cc as well. I'm on E though.
I've got a bunch of these bosch injectors, you can modify them just like the newer subaru pencil injectors. That's all I'm saying..
