Detailing Auto Detailing and Concours
car detailers: flex or cyclo buffer.
Old 01-18-2015, 10:35 AM
raverx3m's Avatar
Default car detailers: flex or cyclo buffer.
what you like better and why?
im hearing both are great but opinions are split between two
Old 02-03-2015, 03:26 PM
Master Detailer
98civdx's Avatar
Default Re: car detailers: flex or cyclo buffer.
Are you only looking between these 2? Have you considered a Griots garage buffer?
I don't experience with the flex, but they definitely make good buffers.
Old 02-04-2015, 11:40 AM
gorillafart's Avatar
are you new to detailing or are you comfortable with cutting and polishing?
the flex is a powerful machine. its like a forced driven rotary but its dual action. meaning it wont stop even if you apply pressure. so theres slightly less room for error with the Flex because its got good torque and still has the safety of dual action. this can be a good or bad thing depending on your skill level.
Im not too familiar with the cyclo. but its pretty big and slightly heavier then most. you do get the benefit of cutting on one pad while simultaneously polishing on the other. or just using both pads for cutting then switching both pads to polishing. two pads give you more surface area so you could possibly finish jobs faster. but with more powerful machines its almost the same same thing. I personally view the Cyclo as a big clunky machine that takes a lot of getting used to but everyone has their own favorite machine.
in my opinion Portercable is good for beginners as well as normal polishing and waxing.
griots garage polisher would be the same but more power.
flex polisher even more power.
then the grandaddy of them all a Rupes polisher.
id say the cyclo would fall inbetween the griot and the flex.
Old 02-04-2015, 06:33 PM
raverx3m's Avatar
I used cyclo and it is heavy but it does cover alot of area and smaller pads allow for tight corners to get polished as well
And its very hard to burn clearcoat With that one.
Old 02-08-2015, 06:38 PM
Detailer's Doma's Avatar
what are your main goals are you using it only for your car?
what type of car?
the Cyclo won't correct paint like the Flex will.
zoopreme
09-21-2010 10:16 PM
Tad
04-05-2010 11:24 AM
killerpenguin21
Detailing
05-29-2009 10:32 PM
prelude1897
Suspension & Brakes
12-08-2008 11:43 AM
vti444
10-31-2007 02:11 PM
Quick Reply: car detailers: flex or cyclo buffer.
