Classic Hondas All Pre-1988 Hondas.
Civic lx 89 d15b2 1.5 stalled while slowind down wont start again, help needed
Old 05-05-2011, 03:39 PM
tchongtching's Avatar
Default Civic lx 89 d15b2 1.5 stalled while slowind down wont start again, help needed
hi,
my civic stalled while driving,
and would not start,
checked the spark and saw small sparks and intermittent ones.
saw my reflection in the throttle body so i have emptied the gas that was flooding that. I am wondering if the flood got down the engine !
the starter seems like its spinning slower now even with jumper cables with another car.
i have checked the mechanical timing and the crankshaft and camshaft are perfect,
with the cam on up and crankshaft aligned with white tab, the rotor is pointing downards a tab to the right when it should be more to the left to point to cylinder 1. cant really figure that one out.
I have checked all the distributors ohms and volts and all of it is good, havent checked the crank angle sensor and have a spare distributor to replace it.
now im wondering if something could have blown like the alternator, or slow the engine down and prevented it from starting.
any help would be great thx.
Old 05-11-2011, 02:39 AM
singlecamsaint's Avatar
Default Re: Civic lx 89 d15b2 1.5 stalled while slowind down wont start again, help needed
any codes on the ecu and isnt this the wrong forum?
Old 05-16-2011, 02:00 AM
I am not a the car right now. I did look at the ecu code, it's a 14 for the electronic air valve I think.
It's one I replaced 4 months ago, the idling would sometimes go way down with a warm engine at a stop so the idling was never perfect.
At the same time I also had replaced the tps, I think the voltage was a bit higher than the requirement, and didn't seem to be adjustable so I just bolted it in, and it worked pretty good, i thought there could be some air in the coolant making the idle unstable at times.
So that could explain the car stalling while I turn into a parking lot,
slowing down.
And then I guess the idle air cv or injectors flouding, could have preventing the car from starting again.
But now, even with a new starter and battery, the cranking speed has lowered from a normal speed down to a way slower one, (who clicked the low setting?) and there seems to be something in the way in the internal mechanics?
What do you think?
I'm about to let it go, any ideas and do you think I should have it diagnosed
by someone qualified?
Thx
Old 05-16-2011, 02:02 AM
I didn't find a category for the 4th generation,
can you tell me how to forward it to the right place?
Thx
Old 05-20-2011, 08:59 AM
letank's Avatar
Thx
I guess this one:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/
ef9_pr0jekt
03-07-2020 07:44 AM
1nv4d3r
08-30-2009 06:46 PM
MrRabbit87
11
10-10-2006 04:22 AM
Kusai.Nihonjin.Desu
08-28-2003 12:49 PM
REDBARON
11-10-2001 09:50 PM
Quick Reply: Civic lx 89 d15b2 1.5 stalled while slowind down wont start again, help needed
