Viper 5901 / 98 accord coupe
I have most of the basic alarm wiring done and everything works but the doors unlocking. Now I am starting the remote start portion of the alarm. car is Auto. which one of these wires do I NEED for remote start to work.
H2 Harness, 18-pin connector
H2/1 - LIGHT GREEN/BLACK - (-) 200mA OEM ALARM DISARM OUTPUT
H2/2 - ORANGE/BLACK - (-) 200mA AUX 4 OUTPUT
H2/3 - GREEN/WHITE - (-) 200mA OEM ALARM ARM OUTPUT
H2/4 - VIOLET/BLACK - (-) 200mA AUX 2 OUTPUT
H2/5 - WHITE/BLACK - (-) 200mA AUX 3 OUTPUT
H2/6 - WHITE/VIOLET - (-) 200mA AUX 1 OUTPUT
H2/7 - GREY/BLACK - (-) DIESEL WAIT TO START INPUT
H2/8 - BROWN/BLACK - (-) 200mA HORN HONK OUTPUT
H2/9 - VIOLET/WHITE - (-) TACHOMETER INPUT
H2/10 - DARK BLUE - (-) 200mA STATUS OUTPUT
H2/11 - PINK/WHITE - (-) 200mA FLEX RELAY CONTROL OUTPUT
H2/12 - ORANGE - (-) 200mA ACCESSORY OUTPUT
H2/13 - PURPLE - (-) 200mA STARTER OUTPUT
H2/14 - PINK - (-) 200mA IGNITION 1 OUTPUT
H2/15 - GREY - (-) HOOD PIN INPUT (N/C OR N/O)
H2/16 - BLUE/WHITE - (-) 200mA 2ND STATUS/REAR DEFOGGER OUTPUT
H2/17 - BROWN - (+) BRAKE SHUTDOWN INPUT
H2/18 - BLACK/WHITE - (-) NEUTRAL SAFETY INPUT
O.G. triple O.G.
Re: Viper 5901 / 98 accord coupe
Here's some more helpful info for you:
http://www.the12volt.com/installbay/...tail/1038.html
As for the alarm module wiring, you will need....
#2 #9 #12 #13 #14 #15 #17 #18
Ok so everything is wired and hooked up but im getting the 7 blinks when i try to remote start.(remote start error). I guess its in manual transmission mode. How do I get it to auto mode? 1998 accord v6 coupe. thanks.
if you have the manual, look for programming sequence. part3 option 1. If you don't have it. follow this. turn key on then off, within 10 sec. press and hold the button on the antenna. you'll hear one beep, then two beep, then 3 beep. release, press, release, and press and hold button. you'll hear one beep. press unlock from remote, wait for two beep to confirm. Now turn key on and off. your done.
Ok so im the button on the antenna and nothing is sounding. It's all integrated.into one plug.correct?
An unprogrammed tach should still at least crank the engine. Plus it's set at virtual tach as default and I've never had a problem with that. 7 blinks is manual transmission mode so you have to change it to auto for it to work.
5 flashes Brake wire is active
6 flashes Hoodpin wire is active
7 flashes Manual transmission mode is enabled and not
initialized.
8 flashes Neutral safety wire has no ground or the neutral safety
switch is Off.
initialized.
switch is Off.
thats the thing, it wont go into valet mode so i can change it to auto, its like the button doesnt even work. The blue light blinks and all but no luck.
If i even heard it crank id be pretty happy lol
Old Fart
OIC, it's not even cranking.
Confirm valet/program button is plugged in properly and to the correct port, [blue].
Are you sure you are going into program mode properly...
Open Door, door trigger must be wired.
Turn ign. on then off.
Press and hold valet/program button, after 3 sec. the siren will chirp once, [menu 1] keep holding valet/program button untill siren chirps a 3rd time, [menu 3] then release, press the valet/program button again and hold it, siren will chirp one more time, [feature 1 auto/manual] do not release valet/program button, use lock/unlock button on remote to change setting to auto, [if your car is an automatic]. 94
Matt93eg
Audio / Security / Video
13
01-11-2010 08:24 AM
