Short in my alarm
Short in my alarm
My battery keeps on dying after sitting for 2-3days. I believe it is my remote starter/alarm.. How can i check for shorts? I took a pyschial look at it the wiring
but didn't see anything bad. The alarm and starter functions good.
any ideas were to look first? maybe testing the unit itself.
I install the alarm myself. it's a prestige 750. first time installing an alarm.
thanks,
thanks,
Re: Short in my alarm (Teken)
Thanks Teken,
i have checked the charging system as much as i understand. here is what i got.
I checked the voltage at the battery terminals, the readings were 12.5 when the
engine is off. With the engine started and no load 13.7v and with full load 12.8v..
I also placed an amp meter in-line with the car off and got .3 amps..
Also, when the battery is low the alarm starts acting crazy, the siren will go
on with a constant non-stop low pitch sound..
I just replaced the battery again. it only lasted 4 months..
Ok, I did the phase one of the testing.. With the A/C, headlights and radio on and
revving the car around 2000rpm, the voltage at the battery terminals is above 13vdc. So i hope that the charging circuit is fully operational.
I can't test the current draw from the alarm until the weekend because i have to get my amp. tester from storage.
But when i do, if the alarm is drawing more than spec. current, what do i look for next u think ? it is a basic prestige alarm: two zone sensor, siren and starter cut off relay and remote starter unit in one..
Thanks again, teken,
Teken, with the new battery every thing is fine. The old battery was only 4 months old. I guess i will have to keep a eye on it. I have no other devices in the car, every thing is stock, only an aftermarket radio. I will keep checking the charging
system and current draw at off position.
Re: Short in my alarm (BK101)
Teken,
i took a current reading of 450ma at the negative terminal of the battery with the alarm active and the car off. Is that normal?
thanks
thanks
Teken, I took that reading from the battery terminal, just to be sure. 450ma is too
high for the drain of the vech.
I will check the alarm devices too.
ntoxicatedtigah
11
05-04-2009 10:54 AM
Prod
Audio / Security / Video
01-13-2004 01:29 PM
