How do I get my Viper alarm out of valet?
Old 09-14-2008, 03:40 PM
Photoshop Guru
ipleadthe5th's Avatar
Default How do I get my Viper alarm out of valet?
I have a Viper alarm that was on the car when I purchased it. I can not get the remote to arm/disarm the alarm but the remote starter works fine. I believe the alarm is in valet mode. Any ideas?
What other info do you need?
Old 09-14-2008, 03:50 PM
fcm
Old Fart
fcm's Avatar
Default Re: How do I get my Viper alarm out of valet? (ipleadthe5th)
The remote start should not work if system is in valet.
What is the model number of the Viper system?
Is the LED on solid, no blinking?
Are you sure it is an alarm/remote start and not just a remote start? 94
Old 09-14-2008, 03:54 PM
Photoshop Guru
Default Re: How do I get my Viper alarm out of valet? (fcm)
Its a 2001 integra straight drive so Im sure its an aftermarket remote start. Im not sure the alarm model b/c it was on the car prior to purchase.
This is what the remote looks like.....
The LED isn't solid or blinking b/c I can't arm the alarm.
Old 09-14-2008, 03:59 PM
Photoshop Guru
I was able to get a solid LED by putting the ign into the on position then off position then pressing the lack program button hidden under the dash.
I was then able to turn off the solid LED by doing the same steps.
Whenever I press the arm or disarm buttons on the remote I get 3 short beeps. The battery indicator shows a fully charged battery.
Old 09-14-2008, 04:22 PM
Photoshop Guru
I figured it out. I had to reporgram the remote and here are the steps...
Step 1: Open a door. (a car door... your car )
Step 2: Put the key in the ignition and turn it to the "Run" position.
Step 3: Push & release the program button (the black button in your car - usually located under dash or driver's kick panel) once and then release.
Step 4: Push & hold the program button in (keep holding).
(Unit -should- chirp once)
Step 5: Press and release a button on your remote (this button will be your arm button)
Step 6: Release the program button.
Step 7: Press & Release the program button.
Step 8: Press & Hold the program button (do not release).
(unit should chirp twice)
Step 9: Press button2 (the disarm button) on your remote.
Step 10: Release program button.
Step 11: Turn key off.
(Unit should emit a long chirp to confirm)
Old 09-14-2008, 04:36 PM
B18C_EJ8's Avatar
Good... Now go back to GDD where you belong...
LOL!!!
Old 09-14-2008, 05:17 PM
Photoshop Guru
Default Re: (B18C_EJ8)
Caught red handed
Old 09-15-2008, 04:16 AM
Photoshop Guru
Well the remote won't hold the program. As soon as I program it the remote works but about 10 mins later it does not. I replace the battery just to be sure that's not what is causing my problems. Now the remote starter doesn't work either.
Old 09-15-2008, 04:43 AM
fcm
Old Fart
fcm's Avatar
Well it is a fairly late model 2way system so remote start will work if system is in valet mode, however when the system is in valet mode the LED will be on solid for about 1 hour after ign. is turned off, if the LED does not come on when you turn the ign. off, the system is not in valet.
Maybe the LED is N/G, try and take it out of valet, these are instructions for a Viper 7900...
“remote” When exiting Valet mode, the remote control
Notification will be two beeps and the Disarm animation.
Use the following methods to enter and exit Valet mode.
valet switch:
a. Turn the ignition on for 5
seconds
b. Turn the ignition off
c. Within 10 seconds press and
release the Valet switch once
d. The led will turn on when
entering and off when exiting
Valet mode
Or you can use the remote...
remote control:
1. Open any door.
2. Press lock button, the system will arm.
3. Press unlock immediately, the system will disarm.
4. Press lock button immediately, the system will enter/exit Valet mode.
5. The led will turn on when entering and off when exiting
Valet mode.
If the above does not work you are going to have to find the alarm brain to get a model number. 94
Old 09-15-2008, 04:56 AM
Photoshop Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">If the above does not work you are going to have to find the alarm brain to get a model number. 94
I can get it in and out of valet no problem using the valet button hidden in the car. I need to locate the brain now
Old 09-15-2008, 05:35 AM
fcm
Old Fart
fcm's Avatar
Let me know when you have it. 94
Old 09-15-2008, 01:56 PM
HONDRETTI's Avatar
did you find it?
Old 09-15-2008, 03:20 PM
Photoshop Guru
Default Re: How do I get my Viper alarm out of valet? (HONDRETTI)
Have not looked for the brain yet. Giving the trophies a bath and putting them to bed. It will probably be Saturday when I get to look at it.
Old 05-11-2013, 09:36 PM
Hong Vic's Avatar
when the car is in VALET MODE can that kill my battery in the car?...
Old 05-11-2013, 09:38 PM
Hong Vic's Avatar
when I bought the car it didn't come with the alarm remote. is there anyway to to buy a replacement for the alarm that was installed on the vehicle? any ideas?
Old 05-12-2013, 07:46 PM
bumpstick's Avatar
it shouldn't. the LED doesn't draw that much power
yes. find the brain and model number, then google "Viper replacement remote."
Old 04-21-2017, 06:49 PM
LinSilDav's Avatar
THANK YOU!
mo5751
Audio / Security / Video
12-13-2012 04:56 PM
DoubleOCivicSI80
21
04-01-2008 08:06 AM
rdssk8rcs1
02-21-2007 09:52 PM
Chiller20
03-16-2002 08:30 AM
Quick Reply: How do I get my Viper alarm out of valet?
