Disabling Ignition Controlled Door Locks for Viper Responder 350?
I have a 1998 Honda Civic CX, which means it came from the factory with no power locks/windows. I have a "Viper Responder 350" 2 Way Alarm installed in my car. The guy I got to install my alarm also installed for me aftermarket door lock actuators.
He set it to the feature where after you actually turn your car on (key into the ignition), the doors lock themselves. How do I undo this? I want them to stay unlocked. Thank you for all of your help.
I looked inside the manual and what not, and it wasn't of much help, it just told me that the feature exists.
EDIT:i can't get in contact with the guy that installed my alarm, that's why I wanna know how to do it myself.
Re: Disabling Ignition Controlled Door Locks for Viper Responder 350?
This a copy paste out of the install manual.
System Features Learn Routine
The System Features Learn Routine dictates how the unit operates. Due to
the number of steps, they have been broken up into two menus. It is possible
to access and change any of the feature settings using the Valet/Program
switch. However, this process can be greatly simplified by using the 998T
Bitwriter. Any of the settings can be changed and then assigned to a particular
transmitter, up to four, a feature called Owner Recognition. Each time that
particular transmitter is used to disarm the system, the assigned feature settings
will be recalled. Owner Recognition is only possible when programming the
unit via the 998T Bitwriter.
If the system was previously programmed using the 998T Bitwriter, the learn
routine may be locked. If the siren generates one long chirp when attempting
to program the unit, the learn routine is locked and must be unlocked using
the 998T Bitwriter.
1.
Open a door. (The H1/5 GREEN wire or the H1/7
VIOLET wire must be
connected.)
2.
Ignition. Turn the ignition on, then back off: (The
H1/9 YELLOW wire must be connected.)
3.
Select a Menu. Press and HOLD the Valet/Program
switch: (The Valet/Program switch must be plugged
into the blue port.) After three seconds the siren will
chirp once indicating entry to the Basic Features Menu
#1. If this is the menu you wish to access, release the
button and go on to Step 4. If the button is not
released, you will jump to the Advanced Features Menu
#2 and the siren will chirp twice. Once you have
selected the desired menu, release the Valet/Program
button and then proceed to Step 4.
19
© 2008 Directed Electronics- All rights reserved.
4.
Select a Feature. Press and release the Valet/Program
switch the number of times corresponding to the feature
you wish to change. For example, to access the third
feature, press and release the switch three times. Then
press the switch once more and HOLD it. The siren
will chirp the number of times equal to the step you
have accessed.
5.
Program the Feature. While holding the Valet/
Program switch, you can toggle the feature on and off
using the remote transmitter. Pressing
will select
the one chirp setting. Pressing
will
select the two chirp setting.
(See Systems Features menus)
NOTE: The Valet pulse count feature (2-5) and the
Channel three timed output (2-9) have five possible
settings each. Pressing
will toggle through all the
two-chirp settings.
6.
Release the Valet/Program Switch.
Once a feature is programmed:
Other features can be programmed within the same menu.
Another menu can be selected.
The learn routine can be exited if programming is complete.
20
To access another feature in the same menu:
Press and release the Valet/Program switch the number of times necessary
to advance from the feature you just programmed to the next one you
want to program.
Then press the Valet/Program switch once more and hold it.
For example, if you just programmed the third feature in the menu and you
would like to program the seventh feature in the menu, you would press and
release the Valet/Program switch four times and then press it once more and
hold it. The siren would chirp seven times to confirm access to the seventh
feature.
To select another menu:
Press and hold the Valet/Program switch.
After three seconds, the unit will advance to the next menu and the siren
will chirp, indicating which menu has been accessed.
For instance, if you just programmed some features in Menu #1 (Basic Features)
and you wish to program a feature in Menu #2, you press and hold the
Valet/Program button. After three seconds, the siren chirps twice indicating
access to Menu #2.
To exit the learn routine do one of the following:
Close the open door.
Turn the ignition on.
No activity for longer than 15 seconds.
Press the Valet/Program switch too many times.
21
System Features Menus
Menu #1 - Basic Features
Items in bold text have been programmed to the default setting at the factory.
Feature One Chirp Two-Chirp
Number Setting Setting
1-1
Active arming Passive arming
1-2
Chirps ON Chirps OFF
1-3
Ignition controlled door locks ON Ignition controlled door locks OFF
1-4
Active locking only Passive locking
1-5
Panic with ignition on No panic with ignition on
1-6
0.8 second door lock pulses 3.5 second door lock pulses
1-7
Forced passive arming ON Forced passive arming OFF
1-8 Automatic Engine Disable ON
Automatic Engine Disable OFF
1-9
Armed When Driving (AWD) Vehicle Recovery System (VRS)
1-10
Code Hopping™ on Code Hopping™ off
the 998T Bitwriter.
1.
VIOLET wire must be
connected.)
2.
3.
19
4.
have accessed.
5.
will select
will
two-chirp settings.
6.
20
want to program.
feature.
access to Menu #2.
21
1-1
1-2
1-3
1-4
1-5
1-6
1-7
1-9
1-10
ny153
10-18-2006 11:40 AM
T Rick
10-03-2006 03:35 PM
