2001 crv with code alarm help
Old 09-04-2010, 08:00 AM
bobertstowers's Avatar
Icon3 2001 crv with code alarm help
Hey folks,
I'm new to this forum and I had a question about my code alarm. I bought the car used and it already had the alarm so I'm not exactly sure which model it is but on the alarm itself it says ca400 which I have tried to research without any luck. The problem is that our remote broke and the system is really sensitive so it goes off not only everytime we get in the car but everytime a large or loud car drives by as well. So I guess these are the main questions.
1. Does anyone know anything about a CA400 alarm? (I've searched google and code's website with out much luck)
2. Could I disable it temporarily until we can figure out which remote we need? (because I've found the remote we have on the Internet but our system isn't listed under the compatible systems.)
I suppose that's it for now. Thanks for the help.
Robert
Old 09-04-2010, 08:14 AM
Post Re: 2001 crv with code alarm help
p.s. Just so I don't get any "all you have to do is change the battery on the remote" replies...i've already done that. And this is what my remote looks like if it helps. http://www.amazon.com/gp/product/ima...1&s=automotive
Old 09-05-2010, 11:50 AM
Cobb2819's Avatar
Default Re: 2001 crv with code alarm help
there is a way to turn off passive arming. according to code's transmitter replacement book. there is no ca400. how did you find out the model number?? also...you mentioned that you found your transmitter online but a ca400 isn't listed, what alarms are listed
Old 09-05-2010, 11:06 PM
DMP
DMP's Avatar
Its probably the Code Alarm Pro400. http://cgi.ebay.com/NEW-Code-Alarm-P...item5ad39a282e
Is there a valet switch installed in your car? If so, you can put it in valet for now.
If the car is too sensitive, the shock sensor needs to be adjusted. Im not familiar with the alarm. I know some Code Alarm units have the shock sensor built into the brain. If its not, then theres a shock sensor that can be adjusted with a small flat tip screwdriver and its plugged into the brain.
leadtrum
Audio / Security / Video
11-09-2008 11:48 AM
allricedout
33
09-01-2007 05:15 PM
Nameless RB26
09-08-2003 08:13 PM
WhOIZiT
07-27-2003 09:18 PM
doe
10
09-10-2002 12:40 PM
Quick Reply: 2001 crv with code alarm help
