03 Civic LX stereo install problem
Old 03-25-2015, 03:36 PM
manhattan84's Avatar
Default 03 Civic LX stereo install problem
I am trying to help a friend install an aftermarket stereo that I had from a previous car that I owned. It is a Pioneer DEH-2200UB. This is not my first stereo install and have pretty good working knowledge of wiring. I know that it works and have checked all my connections from the car harness to the stereo. I am 99% sure they are all good. I have followed the wiring diagram for the car into the deck properly. The unit gets power and when I turn it on I can hear a click/pop from the rear speakers but ultimately no sound. I have checked the fuses that could possibly be linked to the stereo but maybe I'm missing something. If anyone has a direction to point please do so.
Old 03-26-2015, 05:13 AM
MotoCARR's Avatar
Default Re: 03 Civic LX stereo install problem
How are you using a wire harness or are you wiring it straight to the car's radio harness?
Old 03-30-2015, 10:18 PM
I am wiring it straight from the car to the stereo. No harness.
Old 03-31-2015, 07:05 AM
MotoCARR's Avatar
Wire colors, make sure they are all correct.
Old 03-31-2015, 04:50 PM
I am seeing my friend tomorrow and I will double check my connections and make sure they are all making good contact. Hopefully that is all it is....
Old 04-01-2015, 08:48 AM
This is the wiring diagram for the HU. The yellow/green wire from the car isn't in the stereo wire bundle but connected to the 12V acc (cig lighter) adapter. Should I connect them?
Old 04-01-2015, 10:35 AM
Quick update. I just checked the voltage on my speakers. I am getting 12v to left rear speaker but the other 3 are only getting 6. Not sure what that means???
Old 04-02-2015, 09:55 AM
MotoCARR's Avatar
If its not in the radio harness bundle, cap/tape off the blue white on the stereo
Old 04-23-2015, 07:53 PM
cheao's Avatar
Try to find out which speaker is the one that pops. Then you need to follow the wire.if it's cut and touching the metal frame it will pop and cut off the sound. Try to disconnect the speaker wire in back of the stereo. Good luck...
Old 04-24-2015, 08:05 AM
O.G. triple O.G.
NVturbo's Avatar
Don't be a cheapass. Just get a wiring harness from Walmart and be done with. Even though it's not your car, suggest your friend to get one or buy one for him/her.
seraphin
05-26-2015 03:07 PM
JDM_NANO
Audio / Security / Video
12
10-02-2011 05:03 PM
VDM_DC2
10
11-22-2009 06:50 PM
GuCCi_GSR
10-27-2008 05:09 PM
Quick Reply: 03 Civic LX stereo install problem
