Red EG8 Project
Old 01-23-2013, 06:01 PM
  #51
j.red's Avatar
Default Re: Red EG8 Project
Had a $5 ebay **** that I bought when I did the swap because I had other things to spend money on at the time. The coating had been wearing off, so I polished my **** out of boredom to see how it looks.
Working on getting my interior back to a level of clean I can deal with because it had gotten rather dirty at college in the fall. Since I don't have any pics of the interior, they will come in a few days when I reassemble.
Also, new wheels should be here friday.
Old 01-25-2013, 01:07 PM
  #52
j.red's Avatar
I kind of got sidetracked from everything else I was doing when I got home and looked at the porch.
Attachment 533585
Attachment 533586
Attachment 533587
Attachment 533588
Attachment 533589
Old 01-25-2013, 02:39 PM
  #53
b1gshaun's Avatar
nice car man, loving how clean the engine bay looks even with just a minor wiretuck, keep up the good work
Old 01-25-2013, 04:01 PM
  #54
sirisma99's Avatar
I love your thread !!! keep us update
Old 01-26-2013, 06:00 PM
  #55
j.red's Avatar
So this showed up today.
Looks much better with a fresh filter in there.
And I decided to try my hand at making a small splitter. Going to see what I can come up with as far as material for the final product tomorrow.
Old 01-27-2013, 02:28 PM
  #56
j.red's Avatar
Old 02-01-2013, 06:41 PM
  #57
Axix24's Avatar
Car looks good but get rid of that ricer front lip man
Old 02-02-2013, 12:58 PM
  #58
j.red's Avatar
Last I checked it's my car and cosmetics are up to me. And I'm not a fan of the lipless dx bumper.
Old 02-11-2013, 02:23 PM
  #59
j.red's Avatar
Old 02-12-2013, 11:48 AM
  #60
Dc2_ShowStopper's Avatar
Nice buld. GLWP
Old 02-12-2013, 01:18 PM
  #61
400hpcrx's Avatar
looking good great job
Old 02-12-2013, 02:06 PM
  #62
Master Ninja
Eddie's Avatar
Wow one sick 4door.
Old 02-12-2013, 04:35 PM
  #63
j.red's Avatar
Test fit the front today.
hardrace rear camber links on the way for the rear.
Old 02-12-2013, 06:35 PM
  #64
CCoady26's Avatar
Where do you get those invisible wheels from o_O MUST HAVE THEM lol
Awesome build keep up the with the progress!
Old 02-13-2013, 05:07 AM
  #65
Freshdot's Avatar
what size are the wheels? and i'm curious to know how you made this splitter..
Old 02-13-2013, 05:19 AM
  #66
OGxruiner's Avatar
at first i was like
then i was like duh
Old 02-13-2013, 03:28 PM
  #67
j.red's Avatar
15x7 +36 wheels and 205/50R15 direzza zII's
The splitter is mostly an experiment. It's made from 1/16" fiberglass sheet. I cut the template 3 times and used fiberglass resin and then clamped/compressed the layers together between two sheets of plywood one at a time to make it 3-ply. I clamped the plywood with c-clamps all around the edges and then had about 300 lbs. distributed across the center of it.
It's got some flex to it, but I wanted that. I didn't want it to be as stiff as the plywood ones that others make because if I hit something, I want the splitter to give/break well before my radiator support. But pushing down on it, I can compress the suspension.
Old 02-13-2013, 04:16 PM
  #68
Boosted_90Teg's Avatar
Love how your sedan is turning out man. And don't listen to anyone, the lip looks great on there. Is it just me, or does it seem molded on? Could just be the angle.
Do you have extended studs too? But nice work on the 6UL's. I just bought a set of their lugs a few days ago. Eventually I'll be getting a 8" set in black. Do you have a pic at a better angle of the fronts mounted?
Old 02-13-2013, 05:12 PM
  #69
Freshdot's Avatar
dang dude, seems like a lot more work than i had in mind..thanx for the info though looks good can't wait to see it done.
Old 02-13-2013, 06:26 PM
  #70
j.red's Avatar
I'll be doing extended studs next fall/winter when I redo my brakes on all 4 corners. I bought the lugs in august because my previous chrome started corroding after being in use for 7+ years. I couldn't fit the key on some without a hammer. So I opted for some extended ones since I'd be getting the studs soon-ish anyways.
I might be getting the black 949 lugs or other black extended ones. I'm not sure how I feel about the red. But that'll wait till spring time when I finally get to pull it out of the garage and see how it all looks together in the sun. Until then. I wait.
moar pics of the front.
and rear.
Like I said. Hardrace rear camber kit is on the way to get the rear down a little more. Can't roll my fenders back there due to the body work that was done with the honda rot 6 years ago. Cut out, and welded in new sheet. Had to use a little bondo to smooth the transition. Don't want to risk cracking it.
Old 02-13-2013, 11:00 PM
  #71
Yea, it wasn't till after I posted that comment that I went to PCF and saw some pics you posted on there. I actually just bought a 2nd owner, red '93 EG8 to replace my grey one that got totaled this winter in a Hit-N-Run, for 900 bucks! Stock as a rock, clean as.
But anyway, car's looking super clean. I'll let you know how I like the 949 black lugs when they get here. I ordered with them 16 extended ARP's though. Damn glad I got a press.
Edit: And btw, I think the red lugs work really well.
Old 02-14-2013, 02:51 AM
  #72
j.red's Avatar
need new floor mats and reupholster the inserts on the doors.
Old 02-14-2013, 01:00 PM
  #73
CAR looks great..Nice Updates !!
Old 02-14-2013, 04:59 PM
  #74
j.red's Avatar
Just weighed my new wheel/tire combo. Weighs in at 11 lbs. less PER wheel. So 44 lbs. of weight reduction and more importantly, 44 lbs. less rotating mass.
Old 02-14-2013, 05:49 PM
  #75
Crx_owner_20's Avatar
Did a great paint job by just painting it in the garage! Great work man, I'll be watching for some updates.
Quick Reply: Red EG8 Project
