My build up of my New 93 DX hatch
Old 07-01-2009, 06:28 PM
HatchVX's Avatar
Default My build up of my New 93 DX hatch
After my last project got totaled I'm swapping all my part to this one. It will be a slow swap over. As of right now i usually only get to work on it on the weekends. Whenever i do something i will post it up.
Coming home
I will have to cut the tunnel out of my red hatch because the guy i bought it from had a H22 in the car
GSR front Brakes
Tucked the Left side harness. Planing on using a S2000 clutch master to the reservoir off of the shock tower.
Tucked the Wiper Motor wires
Most likely going to put the Fuse box where the ECU was.
When i pulled the door panel i found this
Here is the picture of the Turbo i will be putting on. Its a Version 1 Peakboost kit. (mock up pics on the old hatch)
Old 07-01-2009, 06:36 PM
r_Senik's Avatar
Default Re: My build up of my New 93 DX hatch
looks good
Old 07-11-2009, 05:43 PM
HatchVX's Avatar
Got some more work done on the hatch.
Got the main harness out of the wrecked hatch and got it into the new hatch.
This is where i put the Fuse box
This is where the wires will come in from the engine harness
Got the wires ran along the passengers fender, I still need to extend the wires so that they will reach where i need them.
Here is a pic of my handles, If anybody wants to add a different touch to the interior of their 92-95 civic you can use S2000 inner door handles. The 05' and up have silver painted handles.
Old 07-11-2009, 06:56 PM
Daniel jdm's Avatar
clean coming out good.
keep us updated ha.
Old 07-12-2009, 10:55 AM
blacklablefable's Avatar
Keep it up.
Old 07-12-2009, 03:19 PM
American.Graffiti's Avatar
So far so good.
Old 07-12-2009, 04:06 PM
m00nr0ck Si's Avatar
Clean shell.....Looks like a fun project....Just keep the pics flowing,we love em
Old 07-15-2009, 11:32 AM
jhendry's Avatar
props on that shell it looks fresh. have fun with the build up
Old 07-21-2009, 06:41 PM
HatchVX's Avatar
Another small update, I got started on the engine harness. In August i will be taking a week vacation and trying to get it all buttoned up.
here are a couple pics
Old 08-20-2009, 07:07 PM
HatchVX's Avatar
My New toy. A benen Tripod Front strut bar.
Mmmmmm Benen mmmmmm
Through last week and again today, This little guy has been there. People say that when you have a Praying Mantis with you, you will get good luck. Lets hope so.
Harness is all done on the driver's side.
And the passenger's side harness.
Her new angry face. Oh i cant wait.
My new headlights and corner i got from Ebay. What i like about these are they have the features i like of the OEM and the JDM lights. From the OEM it has the glass lenses, and from the JDM it was the citylights and the non nippled lenses.
The boost solenoid for my Greddy Profect
This is how i ran the headlight and city light harness's. It is the same on the drivers side.
Here is a shot from the passengers side.
The new location for my oil catch can. Still need to get a new filter.
Another shot over the passengers side. The radiator that is in there is dead. It got a hole in it from the accident, It was in there for a placeholder so that i could wire in the fan.
This is how im running the Oil feed line. You can also see the Hasport mount.
This shows my S2000 Brake master and booster, the S2000 Clutch master, and the Cusco brake master brace, repainted black.
Oil drain line and the Hot side of the charge pipes.
View from the bottom, Note the downpipe is not installed yet.
Exhaust housing.
Complete rebuild from Blaast Turbos. Had a piece of welding wire or the such go there and destroyed the Exhaust turbine. Thanks to my brother David (2gr84u) for the rebuild, and alot of the little parts that i needed to get this together.
This I have to say must be the single best thing I bought for this motor, my Fluidampr. This make my motor fell like it has stock mounts.(i have solid mounts all the way around)
Another view of the oil drain. Do you think this will cause a problem?
Fenders back on. The drivers side is all done and aligned, the passengers side still needs some work.
The gaps look damn good on this side. The best part is I got it on the first try. Also got the sidemarker and fender liner installed.
I still need to work this side. Got the sidemarker install on this side also.
The cold side charge pipe. Also the new home for the horn. I need to get these pipes powder coated.
Hot side pipe all installed.
Half the harness done. Still waiting for some larger sleeveing for the other half.
Close up of the sleeving.
Soon to come also is a set of Jim Fab traction bars.
Old 08-23-2009, 07:51 PM
HatchVX's Avatar
Here is what i got done today.
Need to get some bolts to mount this up
Grrrrrrrrr
Right side fit
Left side fit
Would you mess with this? Should I paint the Intercooler black?
Old 08-23-2009, 09:48 PM
maxwellmercer's Avatar
paint it.
Old 08-24-2009, 08:14 AM
Ej8_KiD's Avatar
yes paint it
Old 08-24-2009, 08:51 AM
ken9's Avatar
dope
Old 08-24-2009, 09:11 AM
Slo-mo's Avatar
looks like its coming along nicely
Old 08-24-2009, 03:32 PM
EJ1_Ex's Avatar
very nice wire tuck also nice turbo setup. thumbs up!
Old 09-07-2009, 07:01 PM
HatchVX's Avatar
What i got done over the weekend.
Harness all done
Close up of the harness
Using an 04 accord harness grommet
Harness ran inside.
Under hood fuse box's new home
The engine harness connectors.
MmmMm Jim fab traction bars. And my hood release
Holes plugged up.
Engine harness coming out of the firewall.
The Harness again
Another View of the harness
Traction bar installed on the right side
New drain fitting give me the room I needed
Looks close. But in person I can just about fit my finger in
Another view.
Beefy mounting points for the traction bars.
HVAC all installed
My Omni power 4 bar map sensor.
Benen bar all bolted up.
Where I mounted my Vacuum manifold.
Got the dash installed. Its getting close
Got the front bumper mounted. Decided not paint the intercooler.
Old 10-01-2009, 10:01 AM
jhendry's Avatar
DOPE BUILD. this is exactly where i'd like my car to be but ha if i only had the time. great job on every thing it just looks so clean.
Old 10-01-2009, 11:39 AM
HatchVX's Avatar
thanks, i will try and get some new pics. Its running right now, i have to work out the bugs with my VSS and get my exhaust taken car of.
Old 11-02-2009, 05:49 AM
HatchVX's Avatar
Well this weekend i was about to get me exhaust all welded up. Big thanks to Larry Ledger in Gordonsville VA for the work. It went pretty smoothly, the one major hang up was getting the piping to work with my muffler, but it feel into place. Here are the pics
Before on the left = me going Thor on it. The fix on the Right
All done
The down pipe mocked up
Putting on the nex flex pipe
After the first pass of welding
Downpipe to Test pipe
Completed downpipe and test pipe
Completed B Pipe minus the hangers
V band on the B pipe
weld on the B Pipe
Cleaned up welds on the dump tube
Larry working on the muffler
Muffler done minus the hangers
V band on the Muffler
Hangers
Middle hanger
Custom made rear hanger
View of the B Pipe
Another view of the B pipe
From the Back
These are the V Band clamps that got killed from the Nylock Nuts getting stuck and seizing
EGT bung
View with it on the ground
http://www.facebook.com/v/174560200162
Video of the exhaust.
If anybody needs any fabracation or powdercoating done. Send me a PM and i will send the info for the guy who did my exhaust. Great guy and i love his work
Old 11-02-2009, 06:24 AM
Supreme+'s Avatar
this is/is going to be a big *** dope project!
Old 11-02-2009, 06:37 AM
HatchVX's Avatar
thanks so much
Old 11-02-2009, 09:15 AM
brandonEM1's Avatar
Nice build... Are you going to re-finish the valve cover?
Old 11-02-2009, 09:29 AM
HatchVX's Avatar
yeah, the same guy who my exhaust is going to powdercoat it
Old 11-02-2009, 10:57 AM
jhendry's Avatar
man this is my favorite build page on ht just cuz i love BOOST and i love white eg's sadly your looks 100x better than mine
Quick Reply: My build up of my New 93 DX hatch
