Eran's del Sol Timeline <CR-XTASY> *REDUX*
Old 09-25-2010, 09:18 PM
HT White Ops
Eran's Avatar
Default Eran's del Sol Timeline <CR-XTASY> *REDUX*
Performance
B16A2 block with polished P30 Head
Rebuilt Y21 Transmission with MFactory 4.9 F/D
P73 ITR Intake Manifold
CTR N1 Enduro Crank Pulley
P28 with Demon 1.2 tuned on Neptune RTP
Vision Motorworks 65mm Throttle Body
Weapon R 4-1 Header (Mugen 4-1 Copy)
EG2 SiR Airbox
NGK Plug Wires
Mishimoto Radiator
Honda OEM del Sol VTEC B-Pipe
Spoon Sports Street Muffler
Spoon Sports VTEC Controller
Stance
B+G S3 Coilovers (ITR Spec)
ITR Rear LCA
CTR 22mm Rear Sway
del Sol 22mm Front Sway
ASR Subframe Brace (Grape Drank!)
Ultra Racing Front Tower Bar
Carving Stark RC 15x6.5 +32
Yokohama S.Drive 205-50-15
Carving Stark Motorsports 15x6.5 +45
Kumho ECSTA SPT 205-50-15
Exterior
Civic EX/Si Front Lip
EG2 del Sol Yellow Fog Lamps
CR-X VXi emblem conversion
del Sol 'Two-Way Paradise' sail decals
EDM glass 2-piece electronic leveling Headlamps
OEM Antenna Blockoff
Downstar Inc. Engine Bolt Kit
Interior
Personal Work EQUIP Steering Wheel with Horn Pad
Works Bell Splash 210 Hub
M's Racing (GruppeM) Shift ****
Spoon Sports Titantium Shift ****
TougeFactory Purple Shift ****
Honda Access 'Powered By Honda' shift boot
SRR Ignition Panel with custom 12v socket and Spoon Sports VTEC Controller
Wink RALLY Mirror
EVO II Recaro Speed seats (grey suede / confetti)
Chargespeed Sport FRP Wide Bucket
Chargespeed Sport Carbon Bucket
Wedge Engineering Brackets w/ Sparco Sliders + Sidemounts
JDM Map Lights with Polarg B1 Hybrid VIP bulbs (purple)
EDM/GDM Sun Visors w/ Mirrors
93 Dash (SRS delete)
93-94 del Sol Zig-Zag mats (grey)
93-94 Trunk Latch Delete
94-95 VTEC tachometer
NA Miata green lighting
Custom Headliner
ICE
Odyssey PC680
Sony XPLOD CDX-GT730UI
Infinity BassLink Powered Woofer
Memphis Power Reference Rear Drivers
Diamond Audio Front Components
Monster Cable RCA
Well, as some of you may know, I did a rapid part out of my hatch to make way for the new baby.
This baby.
Yep, I got a Del Sol. On April 23rd, I got over the hatch. It hasn't been what I've wanted for a while now, I just think I was ignoring that little itch. I was even planning to get another hatch to transfer all my parts onto so it would be 'perfect,' but even then I wouldn't be happy. I came across the Sol while searching for '1997 Civic' on Craigslist. As soon as I saw the ad, I fell in love.
I called the guy after sleeping on the idea and having it bounce around in my mind all the next day. When we were driving out to look at it, it was already as good as sold. I barely even needed to look at it. It ran perfect, it looked great for it's age ... it was just right.
I couldn't resist, so I took some pics on the drive back home.
And once I got home, I wasted absolutely no time removing the Alpine deck and installing my beloved Gathers HU.
The next day, I drove down to Portland after work to pick up some B+G S3 ITR-Spec coilovers with some ITR LCA's.
After I got it all put together with the coils and the wheels. I also threw on my CTR exhaust after bending the hangers out and forward to match the Del Sol hangers.
After I was satisfied, I drove to the torn-down 'Up The Creek' Bar+Grille in Shelton to take some pictures.
A couple days later, I got my WINK mirror in from Amazon and installed it. Right now, I have no visors because you have to take out the huge rubber "non-visor" pieces. I'll be getting the EDM visors later.
Took this nifty shot while I was waiting to pick up Amy's car from paint.
I then put on my JDM VXi full decal set, including the rarely-used "Two Way Paradise" wing panel decals.
Last week, I installed my ASR Grape Drank subframe brace and JDM ITR sway bar.
Then that weekend, I picked up a new heart.
05/22/09
05/24/09
Installed GDM/EDM visors and JDM SiR-II steering wheel with uber rare factory leather wrap.
05/29/09
Made some L-brackets for my Wink mirror that work with my EDM visors.
06/03/09
Had some fun with the editing. Very surreal feel to the colors that I enjoyed, sort of a Halloween-ish feel.
06/08/09
SRR Ignition Panel modded to fit a 12v socket and my Spoon VTEC controller.
07/04/09
More:
07/06/09
http://www.flickr.com/photos/erantyint/3695917738/
http://www.flickr.com/photos/erantyint/3695108141/
07/09/09
07/23/09
07/29/09
08/01/09
Gotta go back to my cousin's shop tomorrow to pick some up, after I finish running the RCA's and power up through the car. Going to go around the rear firewall, and then do the typical "down the body seam" ****. Go up behind the glovebox with the RCA's and out the ECU grommet to the battery. Used flat black for the power and gloss black for the ground.
08/02/09
Finished up my subwoofer install and got the deck / amp all tuned up and sounding great no matter what I'm listening to.
I rerouted that ground cable to inside the rear firewall because there was a M5 washer bolt just inside, and it made the operation just that much cleaner. Ran the RCA's under the personal trunk, and then up the center console, and ran them with the deck harness, and tucked it into the flexo around it, so it stays nice and tight and doesn't rub on anything.
Final product:
08/10/09
Made my false floor today out of 1/8" hardboard. Used the original particle board as a template, then cut an 20" x 12" trough. Measured out the sub from there, and ended up with a box about 20" x 16" with an arc at the top. Lined the underside edges of the box with 1/16" x 1/4" foam strips, cut the corners of the fabric, cut a small square out, and folded it over. Used heavy-duty webbing adhesive to stick it to the underside, and then used the fabric I cut out in conjunction with no-slip webbing to make pads.
08/12/09
08/29/09
Oldschool MINE's Racing shift **** I got off an S13 shell for $5. The chrome was chipping off, so I sanded it down to the nickel. Polished it up, but didn't like the look. Took it down to 400g and then to 800g to give it a brushed look.
09/03/09
Before I get seventeen people coming out of the woodwork to tell me how much Sony XPLOD decks suck -- try this deck out first hand. I was VERY surprised. It's got quite a good sound quality, decent preouts, parametric EQ, and has the best iPod interface I've seen on a single-din. It can scroll through artist lists and skip tracks real time.
09/12/09
09/16/09
Got my Spoon Street installed. Woo woo, it sounds good.
09/26/09
Finally....
And I don't think I'm going to candy the lip. I like this WAY too much.
10/11/09
Got a new boob job. LOL!
Shifted them over as far as they could, and filled the old holes with nylon plugs.
10/17/09
Finally found the perfect fabric.
11/09/09
I actually got up off my lazy *** and took some pictures of the car. Feels like it's been so long.
And a little dSoc love.
11/17/09
Mmmmmm. Got my EDM electronic leveling glass headlights in from Amsterdam today. Also wired up a 93-95 AUX switch for my foglights to make room for the leveling switch.
12/13/09
Happy Winter SolStice!
12/19/09
Woohoo. Wired up my city lights and rewired my corners.
Before:
Corner lamps wired as marker lights and signals; City light unwired.
After:
Corner lamps wired as signals; City lights wired as markers.
Headlights / Foglights on.
01/25/10
These were tooooo big.
Now they're for sale.
02/13/10
Did my gauge lighting.
I still need to get a green film for my clock, and also pull my radio so I can do the climate control lights.
Before:
After:
And my Polarg B1 VIP Hybrid bulbs in my map lights.
These ****ers are BRIGHT. Like, I am used to colored bulbs just being pretty, but they put out a TON of usable light.
02/16/10
Playing with the new cam, getting the hang of it.
Realized I was shooting at ISO400 and was unhappy with most of them.
02/19/10
Got my 93 dash in today.
02/20/10
My ITR intake manifold and Vision Motorworks 65mm throttle body with FITV bypass. :bang:
And my BNIB 94-95 del Sol VTEC B-pipe. They're SILVER!
Oh yeah, and Amy just ordered me a present. ONE, yes, one single Work Equip wheel. I mean. What a bitch, only ordering ONE. Come on, lame.
Attachment 540245
Attachment 540246
Attachment 540247
02/27/10
Started cleaning and assembling the swap today...
Need to use some heavy steel wool on the dizzy and see if I can get those spots off. Annoying.
02/28/10
Haven't stripped the letters off yet, still too tacky to risk it. *nervous*
Deschutes Brewery Burgandy FTW.
03/01/10
Wooo!
If all goes as planned, it should start going down next week :scurred: I've been blowing cash out of my ******* like the world was ending, all in prep for this swap to go in.
Monday: 03/01
* Ordered Radiator (eBay motors)
* Ordered Samco hoses (Evasive Motorsports)
* Purchased reinforced tubing for intake manifold vacuum lines (Lowe's)
Tuesday: 03/02
* Aircraft Stripper + 3M Red Pad to Comptech IceBox arm
* Steel wool + WD-40 to Comptech header
* Radiator shipped
* Samco hoses shipped
* Ordered Pivot radiator cap (ICB Motorsports)
* Ordered super secret rare spark plug cover (ICB Motorsports)
* Ordered Vision Technica oil cap (ICB Motorsports)
* Purchased new axles (Autozone)
* Purchased 5qt Castrol Edge 5w30 + Fram ToughGuard (Autozone)
* Purchased NGK iX Iridium spark plugs (Autozone)
* Purchased Fram ExtraGuard (Autozone)
* Purchased Seafoam (Autozone)
* Purchased Denso O2 sensor (Parts Plus)
Wednesday: 03/03
* Purchase 2qt Honda MTF
* Purchase 1gal Honda Super Coolant
* Purchase Redline Water-Wetter (Autozone)
After tomorrow, it's just a waiting game for parts to arrive. :headbang:
03/06/10
Got my Spoon **** today.
03/09/10
The brain!
The heart!
The .... small intestines?
03/16/10
MY CAR RUNS!!!!! SEAKING **** YEAH!
Like I'm talking perfect. Only hitch is I still need that OBD2 IACV, so every once in a while, the idle will stick at 3K (instead of being down around 1K) and I'll have to blip the throttle to make it go back down.
But seriously, my car gets up and goes now. Compared to the Y7, this is like driving a REAL car. That MF 4.9 makes it really fun, it takes me about a block under normal driving conditions to go from 1st to 5th aahahahha.
Seriously jazzed right now. It's like being on coke, except without the need to solve the world's problems and hug someone and "Go out and like ... DO SOMETHING MAN!"
03/17/10
Teaser what?
03/18/10
03/21/10
Ah, the heart is beating.
06/03/10
[b]08/15/10]
Picked up a new driver's seat ...
And in it goes. Removed the passenger Recaro for weight and comfort. Oddly enough, ****er's were heavy. Probably because they were an OEM Recaro.
08/18/10
Redid my valve cover today -- matte textured fade from bright blue to purple. Polished letters and such.
Supplies
Prepped
Textured
Fade
Finished!
N/A Is back!
I got rid of the supercharger on Saturday. Was sick and tired of all the issues and the garbage that's associated with JRSC kits. The brackets fit poorly, it used Allen head bolts (which were of a poor grade), the crank pulley couldn't use an OEM tool, the power it made was NOT impressive, it went through belts, had massive heat soak, blow-by issues, burned through charger gaskets (ended up using Loctite 510 for ****'s sake!), etc etc etc. Sold the kit at a profit though, even considering the money I put into repairs / parts.
So I'm back to naturally aspirated. Snagged a Weapon R header (Mugen 4-1 copy) for DIRT cheap, sold the Comptech to a friend. Still running on Neptune RTP with my AEM UEGO, so I'll be able to squeeze a few more drops out of the semi-stock motor. Got some goodies coming in the mail soon, so beginning of September is going to be fun.
Parts On Order:
* OEM Timing Belt, h2o pump, tensioner, spring, valve cover gasket
* EG6 / EG2 SiR Airbox
* OEM Breather Pipe Setup (metal piping for valve cover breather and FITV)
* CTR N1 Enduro crank pulley + belt
* JDM <super secret / undecided lol> 2.5" Header
* BLOX 2.5" Test Pipe
I'm stoked to actually DRIVE the thing again. It's been down more than it's been on the road, and I'm sick of it. I bought this car to have fun, not to swear at and resent.
09/23/10
Finished the timing belt job, only to have my Demon take a ****. New one from Moates should be here about the end of the month.
Got a goodie at the Nissan showroom today, TougeFactory purple ****. Retapped to 10x1.5 and installed. Inexpensive, and nicer than the BLOX *****. They have a flat bottom instead of being a full sphere.
Old 09-25-2010, 09:44 PM
d00mlol's Avatar
Default Re: Eran's del Sol Timeline <CR-XTASY> *REDUX*
Old 09-25-2010, 10:10 PM
J_Marc's Avatar
One of the nicest Del Sols by far!
Old 09-25-2010, 10:41 PM
mouab18c1's Avatar
Never really liked del sols but dang this one made me change my mind.
Old 09-25-2010, 11:24 PM
butta75's Avatar
This is my new favorite sol. Its the cleanest, and I really love that silver color. Someday my EG8 will be that color..
Old 09-26-2010, 06:08 AM
Lord of the idiots
[ej]Jonathan's Avatar
ive always <3'ed your sol
what are your wheel/tire specs?
Old 09-26-2010, 07:37 AM
HT White Ops
Eran's Avatar
15x6.5 +32, Yoko S.Drive 205/50/15
Old 09-27-2010, 12:57 PM
Flattery Will Get You Everywhere
markspan6243's Avatar
dude i want one of those dSoc stickers!
Old 09-27-2010, 03:28 PM
jdm36's Avatar
damn so nice
Old 09-28-2010, 08:36 AM
JDM.'s Avatar
This makes me want a sol, but i dunno if i can fit in one lol I am 6'5
Old 09-28-2010, 09:33 PM
HT White Ops
Eran's Avatar
I'm 6'1" and I fit fine.
Old 09-29-2010, 06:46 AM
JDM.'s Avatar
I think when i sell my EG I am going to start browsing for a Del Sol now.
Old 09-29-2010, 08:01 AM
k27
k27's Avatar
Like whoa
Old 09-29-2010, 09:58 AM
Spoon84's Avatar
Wheel *****!
By the way nice sol.
Old 09-29-2010, 10:12 AM
mattrt09's Avatar
i LOVE your car i follow it on NWP
Old 09-29-2010, 10:32 AM
super onion's Avatar
i have a soft spot for del sols and your sol takes that spot perfectly. very nice car bro
Old 09-29-2010, 01:56 PM
Banner's Avatar
damn this is nice. good job bro
Old 09-29-2010, 05:16 PM
DrZFiNeSt's Avatar
I suddenly have the urge to get a del sol
Old 09-29-2010, 09:36 PM
MLRtimeSTL's Avatar
nice build!
Old 09-29-2010, 10:20 PM
Original.'s Avatar
I've said it before and I'll say it again. With hella flush, stance, and whatever is "in" now it will soon fade away. But simple and clean will be forever. Good job man.
Old 09-29-2010, 10:23 PM
HT White Ops
Eran's Avatar
Thanks for all the compliments, guys. Finally got it back on it's toes tonight. New Demon board came in last night, repinned the EGR (D12) to my wideband, and it's rolling like a champ. I'd go out and do a little street tuning, but I'd rather finish this bottle of wine and watch a movie.
Don't drink and street tune.
Old 09-30-2010, 05:47 AM
Mattdg67's Avatar
Looks amazing, very clean.
Any "how to" for this one?
Old 09-30-2010, 10:41 AM
HT White Ops
Eran's Avatar
Wasn't too awful hard. I just popped out the whole air vent assembly, took the trim ring off, ground off any tabs inside, cut off a bit of the back side (where it would meet up with the ducting), and massaged it in. Took a few tries, (fit, grind, refit, grind, etc), but it came together nicely. I've still got the modified cup if you want it. All you'd need is your own 60mm gauge and the trim ring from your stock air vent.
Old 09-30-2010, 10:57 AM
inzanejdm's Avatar
this is by far one of the cleanest del sols I've seen. I have the same sony deck my girlfriend brought it for my birthday about 2 years ago now lol I love it cant go wrong with Aux, ipod and xm satelite. SUSCRIBED!
Old 09-30-2010, 02:37 PM
JDM.'s Avatar
That is what I said. lol
Quick Reply: Eran's del Sol Timeline <CR-XTASY> *REDUX*
