Re-honing Cylinder walls?
Just wondering what you guys use to re hone your cylinder walls. I was thinking about getting a flex hone so I can hone the wals on my single cam motor but wasn't sure which one I'd need. Would a 76mm hone work?
Thanks!
Thanks!
Re: Re-honing Cylinder walls? (CptMidway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CptMidway »</TD></TR><TR><TD CLASS="quote">Just wondering what you guys use to re hone your cylinder walls. I was thinking about getting a flex hone so I can hone the wals on my single cam motor but wasn't sure which one I'd need. Would a 76mm hone work?
Thanks! </TD></TR></TABLE>
You would need a stone hone, no harsher then 400 grit. I've heard 600 grit works best.
The is the hone I was referring to. http://www.flex-hone.com/Index...s.htm Just wondering if a 76mm hone would work on a 75mm bore. (Which is what a D series motor is right?)
Re: (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">Don't forget to ask the folks here how to properly clean the cyl. after you hone.</TD></TR></TABLE>
I would like to know!
Re: (Rocket)
Wash the cylinders with warm soapy water, immediately oil to prevent rusting.
Leo.
12-08-2006 02:56 PM
