Quarter Sports H2B Kit
Since Mat is to lazy to do a write up in a forum that actually gets some real people running through it.
https://honda-tech.com/zerothread?id=1475661
He put many passes down with the h-series tranny and his best was:
12.62 @ 107mph
1.7x 60'
After just the straight H2B swap, only 'extra' was a LSD and it was a GSR S80 transmission:
12.40 @ 111mph
1.78 60'
He only made 1 run before he swapped out his shitty OBX header for his new DTR, but in many many many runs w/ the H series tranny vs. the single run he made with the S80 transmission, he:
Gains:
2 tenths ET
4 MPH trapspeed
By the way, he dyno'd at 215whp, i/h/e, cams, flywheel, usdm h22a w/ h tranny and 220whp i/h/e, cams, flywheel, usdm h22a w/ b-series tranny. Both SAE numbers.
PS I challenge all H2B kit owners out there to post their before and after times here!
Modified by DarkKnight1 at 3:28 PM 1/9/2006
12.62 @ 107mph
1.7x 60'
12.40 @ 111mph
1.78 60'
Gains:
2 tenths ET
4 MPH trapspeed
Re: Quarter Sports H2B Kit (DarkKnight1)
Why is it that when I see a 220whp B-series I'm like but when I see an H22 do it, I'm just,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight1 »</TD></TR><TR><TD CLASS="quote">Why is it that when I see a 220whp B-series I'm like but when I see an H22 do it, I'm just, </TD></TR></TABLE>
three words "big block powa"
Re: Quarter Sports H2B Kit (skunked)
good run at cmi last sun. to bad i cant say the same. I couldnt even get the car started once I hit the line haha. Ran into every type of problem. But I do want to look into that H2B comversion.
Re: Quarter Sports H2B Kit (racerx023)
gathering all the components for the kit.. can u guys recommend a place where i can find the single belt crank pulley?.. (other than DH racing..heard some spooky stuff about them).. this is the list i've gathered:
After market clutch
" " flywheel
" " mounts
shift linkage
B series Starter
T bracket for rear mount
Single belt crank pulley
still feels like im missing something..?
After market clutch
" " flywheel
" " mounts
shift linkage
B series Starter
Re: Quarter Sports H2B Kit (SiRTifiedacc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRTifiedacc »</TD></TR><TR><TD CLASS="quote">gathering all the components for the kit.. can u guys recommend a place where i can find the single belt crank pulley? </TD></TR></TABLE>
I just turned down the OEM pulley.
Re: Quarter Sports H2B Kit (xv53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xv53 »</TD></TR><TR><TD CLASS="quote">http://www.aj-racing.com/catal...age=1</TD></TR></TABLE>
dayum......good price!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">dayum......good price!!</TD></TR></TABLE>
i would still turn my stock pulley for only twenty bucks!!!!
Re: Quarter Sports H2B Kit (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">i wonder if this can be done to a 5th gen.......</TD></TR></TABLE>
not easily, the shift linkage would be my concern.......
Re: Quarter Sports H2B Kit (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">this kit has me thinkin of a F20B to go along with my ITR tranny w jdm final drive </TD></TR></TABLE>
yummy
yummy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">this kit has me thinkin of a F20B to go along with my ITR tranny w jdm final drive </TD></TR></TABLE>I was actually thinking about that...that would be sweeeet.
i think i just need some more dyno sheets of stock f20b's with bolt ons... god an 85mm motor with a b16 r/s ratio and a 88mm stroke....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">i think i just need some more dyno sheets of stock f20b's with bolt ons... god an 85mm motor with a b16 r/s ratio and a 88mm stroke.... </TD></TR></TABLE>
put a a H22A4 crank in a F23 block (stock iron sleeves) and forged pistons. That will be damn close, just a little bigger on the stroke and bore.
Re: Quarter Sports H2B Kit (ri_rv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ri_rv »</TD></TR><TR><TD CLASS="quote">can you still retain AC with the H2B kit?</TD></TR></TABLE>
Not without some custom fabrication. The frame rail to pulley clearance is already very tight with a single belted pulley let alone a dual belt pulley.
Gotta love the h series power i got an H22 eg @ 226 WHP N.A and 322 whp on the juice my best et is 11.8 and best mph of 119 on the h tranny..soon to do the H2B kit i hope to get into the mid to low 11's...
