power of main bearings SPOON
Old 12-28-2011, 12:02 PM
  #26
Max[RUS]'s Avatar
Default Re: power of main bearings SPOON
Originally Posted by josephcmiller2
Engineer is not necessary. You are building a unique engine. Experience is necessary. You can obtain experience from testing. You can obtain experience from people who build 11,000 RPM motors.
11,000 RPM motor is not normal. Normal engineering does not work. You can not know that 11,000 RPMs will make the parts resonate and vibrate. Only experience tells you how 11,000 RPMs affects the motor.
perhaps this is a comprehensive response ... Thank you!
Will build on the principle of all means are good)))
Old 12-28-2011, 08:10 PM
  #27
Twenty47's Avatar
i thought people go over 10k on b16b's pretty regularly? without that brace.
Old 12-29-2011, 05:10 AM
  #28
josephcmiller2's Avatar
Post links to some threads. This guy is looking for a place to start.
Old 12-29-2011, 05:26 AM
  #29
Black R's Avatar
Originally Posted by mcvtec
He's joking.
Forget the Spoon blade, look at this about half way down the page:
http://www.erlperformance.com/produc...formance-parts
Rmember that you will need to dowel pin this in order for it to be of any use.
Jim Justice did mine.
Old 01-01-2012, 01:20 PM
  #30
Uncle Dave's Avatar
http://www.youtube.com/watch?v=0K2xT...eature=related
This shows the block blade alittle better.
Old 01-01-2012, 06:05 PM
  #31
hondasdohc's Avatar
like i stated before it's just the block girdle that's what helps in 10k revs without blowing something up. Now that's why the F20c, K20's, and the famous f20b rev high without complications.
MHBb16CRX
05-14-2010 04:23 PM
jeffk182
31
06-23-2004 12:41 AM
Quick Reply: power of main bearings SPOON
