port and polish myself?
Old 10-10-2003, 06:40 AM
milanoGSR's Avatar
Default port and polish myself?
what exactly do they do in a port and polish? why doesnt anyone do it themselves? i'd like to learn how to do it myself.
Old 10-10-2003, 06:43 AM
1999all_motoR_teg's Avatar
Default Re: port and polish myself? (milanoGSR)
You should port and polish your engine not yourself j/k
Well if you want to learn how to do it then more power to you. Just make sure you learn from someone good.
Old 10-10-2003, 11:19 AM
machine4321's Avatar
i think cleaning up the ports is ok to do your self...i would never want to start hogging out my head but a polish i would do in a second
Old 10-10-2003, 03:52 PM
Mentat Ghola's Avatar
Default Re: (machine4321)
I have the equipment in my engine performance class. Ported/polished my b16 head and installed ITR valvesprings. It takes time, patience and control. A beginner should only polish and not mess with the ports.
Old 10-10-2003, 03:55 PM
chrisCNL's Avatar
Default Re: (Mentat Ghola)
do you have a bench flow machine. If not let the peeps who has a bench flowing machine do your work so the flow rate is the same in all of the port.
Old 10-10-2003, 04:07 PM
mastarolla's Avatar
Default Re: yea
if you look...i believe it is number 2 or number 3 cylinder which runs a little bit leaner than the rest of the cylinders for some reason. Perhaps you could find a way to correct this yourself?
Old 10-10-2003, 04:33 PM
GSRswapandslow
Guest
Posts: n/a
don't **** it up
http://www.hondaraceengines.com
they are the cheapest, and by FAR the best.
just e-mail Brad of PM him at Max_CFM on here.
Old 10-10-2003, 05:42 PM
HEAD's Avatar
Default Re: (GSRswapandslow)
I think I need to make a video for this. my suggestion is to use a cast iron burr if you plan on taking any material out because it won't get away from you like a aluminum burr will use it on a slow speed with lots of lube, you can order that stuff from Standard Abrasives. If you haven't bought a grinder yet I suggest a air grinder with a front exhaust so it will help blow the wasted material away or a electric grinder but I cannot suggest which one because I don't use them.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow &raquo;</TD></TR><TR><TD CLASS="quote">don't **** it up</TD></TR></TABLE>
I agree and good luck
Old 10-11-2003, 12:39 AM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milanoGSR &raquo;</TD></TR><TR><TD CLASS="quote">what exactly do they do in a port and polish? why doesnt anyone do it themselves? i'd like to learn how to do it myself. </TD></TR></TABLE>
Try and it and you'll see why many don't do it. It takes a certain passion along with grinder control, and some initial equipment.
Old 10-12-2003, 08:54 AM
Default Re: port and polish myself? (Rocket)
If you actually want to reuse the head, i suggest u dont use a burr. It will take off too much metal, and you could seriously mess up the port job. I suggest just using sandpaper bits and smoothing out the ports.
Old 10-12-2003, 10:48 AM
milanoGSR's Avatar
Default Re: port and polish myself? (Mentat Ghola)
hmm...maybe i'll just do a polish.
Old 10-12-2003, 10:50 AM
advanracing62's Avatar
it definately takes patience and practice...
Old 10-12-2003, 03:22 PM
HEAD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola &raquo;</TD></TR><TR><TD CLASS="quote">If you actually want to reuse the head, i suggest u dont use a burr. It will take off too much metal, and you could seriously mess up the port job. I suggest just using sandpaper bits and smoothing out the ports.</TD></TR></TABLE>
that is why I suggested that anyone trying this to use a burr that has a cast iron cut so it won't take out alot of material, If your not going to take any material out I wouldn't waste my time doing it, I don't think you would see any gain at all by just polishing.
gavinoauto
07-04-2008 11:49 AM
GUILOTINE
24
12-14-2005 04:16 PM
EG6R
03-14-2005 06:27 AM
HondaH22A
12-15-2002 10:39 AM
canuck-mx6
12-08-2001 10:36 PM
Quick Reply: port and polish myself?
