Oil turning black too soon?!
#26
Re: Oil turning black too soon?!
Change it your oil, give it a new filter and keep out of tec. Check it at 1500 miles. See if theres a difference. By all means, check your oil for grittyness etc before changing. If it doesnt feel gritty or smell really bad, keep going with it. If the consistency of your oil feels and smells fine, but is just black in color I'd just wait to change it. And when you do, try what I said first and see if theres a difference. Chances are its just carbon from being richy-rich and hitting tec.
#28
When you are in tec, it dumps more fuel to compensate for extra air being sucked into the cylinders from your extra lift... More fuel means that you are going to be running richer... More fuel= more carbon. that carbon will get trapped in the thin layer of oil that is on your cylinder walls. That oil is then scraped off by your rings and will eventually get mixed in with the rest of your oil. carbon in your oil. Makes it turn black.
#29
but since the ecu is compensating for the increased air flow, wouldnt the a/f ratio still be burning efficiently, and not causing it to run rich?
#30
My car turned fresh oil black in about 200 miles when I bought it. I used GUNK internal engine cleaner (Very thin stuff. Add to crankcase, idle for 5 minutes then drain all oil and put in fresh). I also used Auto-RX, 2 or 3 bottles. After many oil changes (6 or ten, something like that) it stopped going black so fast, now stays reasonable through 3000 miles. BUT it burns oil like crazy, and I'm still wrestling with that. 20-25 oz per 1000 miles. I drive 600 miles /week so I check it every day unless the weather is insanely bad.
ECU generally is programmed to richen up the mixture when you open up the throttle all the way or nearly all the way. I'm told the extra liquid is there for cylinder cooling. Ya wanna go fast, it will cost you in fuel. No big surprise.
Of course whatever fuel is "extra" beyond matching the amount of air, can't combust in the cylinder so it burns in the cat converter. Unless it gets past the rings...
For blackish oil - I was gonna suggest just changing the filter, not the oil. I tried it once on blackish oil and it cleaned it up nicely. Of course you might not want to if you're using $10-15 filters. I use Honda filters, not tooo pricey.
#34
The color of the oil doesn't have anything with how well it's working. The only way to answer if anything is wrong with your engine is to have the oil tested at a lab like Blackstone.
#35
update: so I topped off my oil and have been staying out of vtec, and the oil looks better and I am burning little or none of it. seems to me like just normal b16 with 149k of hard driven miles. probably just losing oil through seals/rings during vtec because of higher pressures. I had suspected this from beginning, just wanted to see if anyone could tell me something I was missing. thnx guys!
#36
holy **** u guys noe alot lol. i was having this problem too in a b18c motor and i been trying to figure it out now i will try everything u guys said. lol besides the seafoam part lol
#37
Purpose Built
