Proper way to adjust FPR
Old 06-19-2003, 11:50 PM
J2turbo21's Avatar
Default Proper way to adjust FPR
I did a search and this is what I got.
From what I read the proper way to adjust the FPR is to pull the vac line off and plug it,then adjust the FPR.Doing this is the fuel pressure you get at WOT.Or you can adjust the FPR while the car is off according to the hondata website.
Here is a quote that I got from HT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">When you read it with the hose on you are reading the regulated pressure. You set the pressure for WOT under load since that is when you are gonna need the fuel. Since getting the car to WOT and under load in your garage is difficult to do the easiest way is to pull and cap the vacuum line. This is basically what the car does when you floor it. By shutting off/removing the vacuum you open the regulator up all the way. This is where you set your pressure.</TD></TR></TABLE>
Here is what I got from Hondata:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The fuel pressure should be measured and adjusted without the engine running. If the engine is running then the manifold vacuum will cause the fuel pressure regulator to lower the fuel pressure. Since manifold vacuum is dependent on idle speed and cam timing, this is not an accurate and repeatable way to measure or set fuel pressure.
To measure or set fuel pressure switch the ignition key to on but don't start the engine. The fuel pump should prime the fuel system. You may need to flip the ignition key between off and on repeatedly.
During a dyno run under full load check that the fuel pressure is correct. For naturally asteriated cars the fuel pressure under load should be the same as the static fuel pressure. For forced induction cars the fuel pressure should be the static pressure plus the manifold pressure.</TD></TR></TABLE>
Let me if this is the correct way to adjust it.Also what is Static fuel pressure,is that when the vac line is pulled?
Old 06-20-2003, 03:31 PM
J2turbo21's Avatar
Default Re: Proper way to adjust FPR (J2turbo21)
Anyone?
Old 06-22-2003, 06:20 PM
smokey2.0's Avatar
damm, i got to try that. i thought it was only done with the engine on, removing the vacum line and adjusting the pressure. but i have alwasys noticed, that when you prime the pump the gauge shows a oressure reading! i'll try to adjust it with the engine off, and see if it makes a difference!
Old 06-23-2003, 07:30 PM
smokey2.0's Avatar
Default Re: Proper way to adjust FPR (smokey2.0)
J2turbo21: last night i adjusted my fpr to 50psi using the hondata method, when i turned the car on this morning i noticed that the gauge was reading 60psi and not 50 or &lt; like i thought it would. i quickly pulled the vaccum line, and adjusted it back to 50. did this happenned to you, when you used the hondata method?
Old 06-24-2003, 12:01 AM
J2turbo21's Avatar
Actually i havent tried either method hehe I posted this to see if others agree so i can try it.My car isnt running and i was gonna try it on my friends crx.
When you adjusted it like hondata said did you start it up after or not until the next day?
Old 06-24-2003, 01:01 AM
smokey2.0's Avatar
i started it the next day, maybe next time i'll do it all in sequence!
Old 06-24-2003, 04:12 PM
J2turbo21's Avatar
Try it both ways i listed and see what happens.Also if you try it the hondata way see what happens when you start the car up right after.
Old 06-24-2003, 07:27 PM
smokey2.0's Avatar
i'll try both ways when i get some time, i'll keep you posted!
Old 10-25-2003, 01:38 PM
ionic_slim's Avatar
So what is the correct way??
Old 10-25-2003, 02:23 PM
filtereds0ul's Avatar
do you cap the vacuum line from the manifold or from the regulator?
Old 11-08-2005, 07:29 AM
W O T's Avatar
Default Re: (filtereds0ul)
bumo for some good questions that need answerring
Old 11-08-2005, 07:59 AM
drdisco69's Avatar
Default Re: (W O T)
It's not hard. You want to meausure the pressure with respect to atmospheric pressure, so you must disconnect the vacuum line and plug the manifold side to keep the idle steady. Adjust the fuel pressure with the engine running, so the fuel pump keeps running and keeps the system at a constant pressure. Put the vacuum line back on and close the hood.
integra3586
03-10-2006 10:17 AM
WayFastWhitie
11-30-2004 05:50 PM
andrewasf77
06-15-2003 12:04 PM
TakaIntegra
06-18-2002 06:30 AM
spankaveli
04-08-2002 05:30 AM
Quick Reply: Proper way to adjust FPR
