intake air temps on a all motor build
Ginger Kid
I have a ls/vtec running s2p2 cams and 12:1 compression or so. I have extremly high iat's, what could help this?? or what could cause this? I am having iats that are nearly 140 degrees. This seems to be too high considering my buddies car is running at 80 to 90 degree iat's. My compression across the board doesnt vary more than 10 psi from any cylinder...what could it be?
Re: intake air temps on a all motor build (pomansouth01)
Is your IAT in the same place your buddies' are?
IAT readings from the intake arm (like on a '99-'00 Civic Si) will be much lower than say the location of the IAT on an OBD-1 GSR (on the manifold).
Ginger Kid
aebs intake manifolds on both motors, only difference I can come up with is lower compression(stock b16) and coated header... We both have the hondata thermal gasket
Ginger Kid
well any ideas on what could cause iat's to be that high??
would it have to do with running stock timing on this map(street tuned for a base map with crome)
Where do each of the intakes draw air from?
Are you measuring under similar conditions? IAT's fluctuate a lot while driving. It's affected by the time spend idling, time spent driving, throttle angle and duration of a given angle, etc.
Ginger Kid
im not sure exactly what I did before the datalog took place, I know one time I sat in one spot getting idle staightened out, it may have been before this run, but it stayed the same for about a hour...bah I would just like to get it down to be able to get more power from it..
Re: (pomansouth01)
You could disconnect the coolant lines from the TB and iacv. Get a cold air intake, and wrap it in the heat reflective tape.That could help a little.
Re: (pomansouth01)
not to sound like a jack *** but why don't you buy a Honda book and look it up instead of relying on someone else to just give you the answers. Besides you can compare and make sure the answer is 100% correct. Because if it isnt who you going to blame if something goes wrong your self or someone that gave you a answer with out you doing your own homework.
Re: (pomansouth01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 »</TD></TR><TR><TD CLASS="quote">crome pro</TD></TR></TABLE>
when you start the car is the air temp low and go up from there or does it stay high all the time? there might be a problem with your sensor did you try to swap out with 1 of your boys cuz it only takes about 2 sec to do so
NICE GUY
Re: (pomansouth01)
i guess your buddies car is way cooler than yours !!!! when we tuned my car last my iat was higher, but prob. cause we ran it hard for about an hour !!
Steven: im thinking about wraping my cai, what ya think !!!
Ginger Kid
Re: (racerx023)
how about you show me which service manual will tell me why my fully built LS/VTEC is running with high iat numbers....
Ginger Kid
I suposed I can switch sensors real quick to see if it makes any kind of difference... I will also route the pcv system away from my intake manifold, I think that may have some to do with it as well..
NICE GUY
Re: (pomansouth01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 »</TD></TR><TR><TD CLASS="quote">how about you show me which service manual will tell me why my fully built LS/VTEC is running with high iat numbers....</TD></TR></TABLE>
i think its the blue one with that honda and acura on it . lol
NICE GUY
Re: (pomansouth01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 »</TD></TR><TR><TD CLASS="quote">what did autoworks say about that header wrap??</TD></TR></TABLE>
he didnt know for sure. he said like $25 but not sure for how many feet!!!
NICE GUY
Re: (pomansouth01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 »</TD></TR><TR><TD CLASS="quote">I suposed I can switch sensors real quick to see if it makes any kind of difference... I will also route the pcv system away from my intake manifold, I think that may have some to do with it as well..</TD></TR></TABLE>
nuclearhappines
01-04-2006 07:03 PM
