HELP NO SPARK
HELP NO SPARK
Ok heres the deal. I have a civic DX with a JDM B18C and a MSD SCI and blaster SS coil. I have spark from the coil to the Dis. Cap but no spark from the Cap to the plug wires. i checked the cap and i supplied 12 volts to the treminals so i know the cap is good. and i wouldnt get spark from the coil if the if the ignitor was bad. I checked the rotor with 12 volts and its good too. i checked the wires with 12 volts also. im stumped on this one!! PLEASE HELP. Thanks.
Re: HELP NO SPARK (EJtypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJtypeR »</TD></TR><TR><TD CLASS="quote">i will do that, i check some fuses and nothing seems to be wrong...</TD></TR></TABLE>
get rid of that crap igntion and stick with oe
Re: HELP NO SPARK (ONEPOINT6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONEPOINT6i »</TD></TR><TR><TD CLASS="quote">
get rid of that crap igntion and stick with oe</TD></TR></TABLE>
and that helps his situation because?
getting back to the original question if your getting spark at the coil, but not at the wires, it could be u have the wrong dist cap or rotor, check and see if that rotor is making good contact with the terminals on the cap
Re: HELP NO SPARK (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">
getting back to the original question if your getting spark at the coil, but not at the wires, it could be u have the wrong dist cap or rotor, check and see if that rotor is making good contact with the terminals on the cap</TD></TR></TABLE>
ive had that set up for a while with no problems i dont see how all of a sudden the cap be bad...i check all the contact points to see if there are any breaks and nothing seems to be wrong. the only think i can think of is in side the dist. theres a little box with spade connectors. and that could maybe be bad but other than that im stumped on this one.
you answered your own question buddy
Re: (EJtypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJtypeR »</TD></TR><TR><TD CLASS="quote">I FIGURED IT OUT....it was the shitty MSD Dis. cap. changed the cap and fired right up. hope this thread will help someone else out too.</TD></TR></TABLE>
incertitude
15
11-18-2003 11:15 PM
