Gaskets, Seals, & O-Ring's Oh my!
Old 05-15-2016, 03:04 PM
B20VSi2000's Avatar
Default Gaskets, Seals, & O-Ring's Oh my!
Good afternoon HT.
I need some assistance, I can't seem to find another thread that completely answers this question, I suspect this could be helpful to someone else in the future if we can come up with everything.
What I'm trying to do is comprise a list of every gasket, seal, and O-Ring that is used in the assembly/installation of a B-Series. Reason being is, that's what I'm doing, and I think I'm missing a couple, need to get it figured out.
This assumes you have the valvetrain installed in the head.
The ones that I'm aware of are as follows
1.) Head Gasket
2.) Intake Manifold Gasket
3.) Exhaust Manifold Gasket
4.) Oil Pan Gasket
5.) Oil Pump Seal
6.) Oil Pump small round gasket
7.) Oil Pickup Tube Gasket
8.) Water Pump Gasket
9.) Oil Control Orifice (Between Block & head, center area of intake side) [Does this O-ring go in between the block & Head?]
10.) Rear Main Seal
11.) Thermostat Housing Gasket
12.) VTEC Solenoid Gasket
13.) Oil Control Orifice (Center Cam Cap) O-Ring
14.) Spark Plug Seals
15.) Valve Cover Gasket
16.) Injector Grommets (Fit into Intake Manifold)
17.) Cam Seals
18.) Exhaust Cam Plug/Seal
19.) Water Pipe (O-Rings on both ends)
20.) Lower Timing Belt Cover Gasket
21.) Upper Timing Belt Cover Gasket
Please reply with any missing.
Old 05-16-2016, 04:38 AM
Fish Twig
tony_2018's Avatar
Default Re: Gaskets, Seals, & O-Ring's Oh my!
Because Honda oem parts site list them for you when you select a certain section of the parts list.
phyzJunkieCivic
09-17-2006 04:41 AM
O16581724 5 2 5
06-23-2005 07:07 PM
TurboTeG4
02-11-2005 05:36 AM
Jonathan_ED3
04-11-2003 09:02 PM
Quick Reply: Gaskets, Seals, & O-Ring's Oh my!
