crank position sensor keeps going bad?
Old 04-18-2006, 04:19 PM
Spence's Avatar
Default crank position sensor keeps going bad?
Hey guys so this is the second distributor that i have had the crank position sensor go bad on what could cause this in my motor? I believe its a bad product but i cant prove it i dont feel that a cps is going keep going bad in my motor.
Thanks
Spence
Old 04-18-2006, 07:41 PM
Spence's Avatar
Default Re: crank position sensor keeps going bad? (Spence)
bump for help
Old 04-19-2006, 04:40 PM
Spence's Avatar
up
Old 04-20-2006, 03:55 AM
Chillinit's Avatar
Is your motor OBD1 or OBD2? If its OBD2, I think the crank position sensor is near the crank sprocket.
Old 04-20-2006, 06:54 AM
cxcivic's Avatar
Default Re: crank position sensor keeps going bad? (Chillinit)
if you still lived in Tampa, i could help ya
Old 04-20-2006, 07:30 AM
Ruben19's Avatar
if the motor is obd2 the crank sensor is located behind the crank pulley.
obd1 you dont need this sensor.
Inside the distributor you have the cam sensor
Old 04-20-2006, 08:11 AM
cxcivic's Avatar
Default Re: (Ruben19)
there is only one ckp(code4)...in the dizzy. The other one near the crank is a ckf...crank fluctuation sensor.
Old 04-20-2006, 01:50 PM
Spence's Avatar
Neal i dont live in tampa anymore
The motor is obd1 and it through this code only once the other day for the first time since the new dissy this car is not a daily driver now its pretty much a maybe once a week drove car. But everytime it throws this code it goes into limp mode which is very annoying. Neal do you think it maybe wiring? You remember my white hatch that had that torn up wires under the dash. maybe you have a dash harness laying around for a eg
hope this helps
Old 04-24-2006, 04:11 PM
Spence's Avatar
bump for some help from mr. cxhatch Neal Sutton
Old 04-24-2006, 09:35 PM
cxcivic's Avatar
check the blu/green& blu/yel wires at B15 and B16(B is middle plug...these wires are on the end) at the ecu....also same color wires at the dizzy plug. hope this helps some
Old 04-24-2006, 09:37 PM
cxcivic's Avatar
....and i do have the complete body harness if you need it.
akinas-crx
10-28-2011 06:00 PM
teddy_dc2
10-04-2007 07:54 PM
FOMULA91
11-17-2005 10:33 PM
EKB18BPR3
03-13-2005 07:22 PM
Quick Reply: crank position sensor keeps going bad?
