LS VTEC oil line thickness?
Old 02-13-2004, 09:29 PM
fakawot's Avatar
Default LS VTEC oil line thickness?
My LS VTEC is fukin slow. compared it to my frenz motor and the only diference is that my oil ine is like 4 times fatter than his. Do i need to reduce my oil line size to get more oil pressure to the head or something?
My vtec kicks in but i feel my car lag big time it's slower than a stock LS
HELP
Old 02-13-2004, 11:42 PM
mr. wu's Avatar
Default Re: LS VTEC oil line thickness? (fakawot)
try checking you timing.
Old 02-14-2004, 12:55 AM
ArinX's Avatar
what size is your braided hose.
Old 02-14-2004, 01:16 AM
JUNcr-x's Avatar
Default Re: LS VTEC oil line thickness? (ArinX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX &raquo;</TD></TR><TR><TD CLASS="quote">what size is your braided hose. </TD></TR></TABLE>
ditto
Old 02-14-2004, 09:04 AM
hotintegranights's Avatar
Default Re: LS VTEC oil line thickness? (mr. wu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. wu &raquo;</TD></TR><TR><TD CLASS="quote">try checking you timing.</TD></TR></TABLE>
take off your valve cover and check your cam gear timing,also timing belt mark. when i first installed my b20 i felt so much lag ,felt slower than my old ls block, then i checked the cam gears and timing was off by 1 teeth. after that it was torque heaven
Old 02-14-2004, 12:07 PM
91integraLSVTEC's Avatar
Default Re: LS VTEC oil line thickness? (hotintegranights)
i think my ls/vtec oil line is to thick also.. the skunk stage2 cams in my b16 used to scream , almost deafing.. now in my ls/vtec i can barly hear my vtec engage!! my car is by far from slow tho =op
Old 02-14-2004, 01:02 PM
JUNcr-x's Avatar
Default Re: LS VTEC oil line thickness? (91integraLSVTEC)
if your oil line is the wrong size im pretty sure the vtec wont kick in! what i ve found the best is to run it off the oil pump! a 90degree from oil pump straight to the head where ls/v is normally tapped! run a 6an....alll the cars have never had any probs with this...but u gotta get a longer alternator belt so the 90degree fitting can fit! it all imo....
Old 02-14-2004, 02:12 PM
King Tut33's Avatar
Default Re: LS VTEC oil line thickness? (JUNcr-x)
I personally believe the bestsetup is the oil filter adapter and a -6AN line. What size line are you running. I know guys run the -4AN with no problems as well.
Old 02-15-2004, 03:33 AM
mr. wu's Avatar
Default Re: LS VTEC oil line thickness? (King Tut33)
i run a -4an line with no problems
Old 02-15-2004, 07:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUNcr-x &raquo;</TD></TR><TR><TD CLASS="quote">if your oil line is the wrong size im pretty sure the vtec wont kick in! what i ve found the best is to run it off the oil pump! a 90degree from oil pump straight to the head where ls/v is normally tapped! run a 6an....alll the cars have never had any probs with this...but u gotta get a longer alternator belt so the 90degree fitting can fit! it all imo....</TD></TR></TABLE>
not if you have a vafc, vtec will activate regardless
Old 02-15-2004, 07:49 AM
does anybody know what size is that?? is that line to big or is that ok??
Old 02-15-2004, 09:10 AM
snowseeker's Avatar
Looks like a -8 to me. You like to keep your engine clean huh?
Old 02-15-2004, 09:32 AM
Formerly Mike@TSR
Mike@CCT's Avatar
It doesnt matter if you have a VAFC or not. VTEC wont engage if the oil pressure isnt there. The only thing the VAFC does is turn the solenoid on at your desired point... Drive with one quart of oil in the engine and tell me if Vtec still works.
Old 02-15-2004, 10:29 AM
Default Re: LS VTEC oil line thickness? (TSRperf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TSRperf &raquo;</TD></TR><TR><TD CLASS="quote">It doesnt matter if you have a VAFC or not. VTEC wont engage if the oil pressure isnt there. The only thing the VAFC does is turn the solenoid on at your desired point... Drive with one quart of oil in the engine and tell me if Vtec still works. </TD></TR></TABLE>
nah i'm good, i'll take your word for it but are you saying because the oil line is so big that there wont be enough oil pressure to activate vtec?
yeh i know i have a dirty engine bay, i'll get around cleaning some day lol theres so many things to fix in the car
Old 02-15-2004, 10:45 AM
Se-rv-Tak's Avatar
Im not running a big line at all, I am using the same size, as ur's 91int.ls.
But TSR is correct, you will not engage vtec if you do not have enough oil pressure.
Old 02-20-2004, 07:09 PM
JUNcr-x's Avatar
the larger the hose the less pressure! vtec needs a certain amount of pressure to activate! not sure what size line that is but 6an is the biggest ive seeen personally! i would only run that off the oilpump....but thats me!
Jeanious
10-20-2007 07:49 AM
Franken Hatch
16
10-03-2006 07:42 PM
Touge Tuning
07-25-2006 04:16 PM
GDM Z28
11-28-2004 08:40 PM
kerby116
02-29-2004 05:33 AM
Quick Reply: LS VTEC oil line thickness?
