Is a -8AN fuel feed line too big for Walbro 255 inline?
It has an inside diameter conversion of 1/2" and the -6AN has a 3/8" inside diameter conversion. I figured that the pump itself may have high pressure, but can't fill up, and keep filled up, a 1/2" hose quickly enough. That's why I was considering -6AN.
Can anyone relate to this? I would like to mount the little fuel cell up front under the hood if at all possible.
Re: Is a -8AN fuel feed line too big for Walbro 255 inline?
the -8AN should work just fine, the one thing you could use the -6AN would be the return line .......or your supply. either way both will work
once the line is filled, it should have no trouble keeping it filled. once filled, it will still be flowing the same amount of fuel.
MarkosMotorsports
05-24-2004 06:58 PM
