81.25 bore...better to use Cometic 81 or 81.5mm ?
I have a 81.25mm bore...should I use the Cometic 81mm head gasket or the 81.5mm? They do not make a 81.25mm one. The pistons that I will be using will not stick out of the head so I hope that piece of info helps....it is .014 in the hole. Thanks
Re: (lvcrx)
I'm using an OEM 84mm on a 84.5 bore. Yes its a larger bore but its the same concept. If it will work for 0.5 sizes overbore it will also work for 0.25
Re: (candy eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by candy eg »</TD></TR><TR><TD CLASS="quote">i have a 81.25mm also, and i use the oem honda 81 one with no problems.</TD></TR></TABLE>
didnt you blow that motor?
Re: (racerx023)
I guess what I am asking is since the 81mm OEM gasket is actually 82mm, are the Cometics the same way ie....the 81mm actually an 82mm, the 81.5 actually a 82.5........you all see what I am getting at?
Master23
03-08-2006 01:18 PM
Bigjussin
11
04-16-2005 02:57 PM
hondaapi
10-20-2004 09:42 PM
