Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
2017-2020 NSX Ignition coil wiring diagram
Old 09-30-2021, 11:35 AM
Freedo_Civegra's Avatar
Default 2017-2020 NSX Ignition coil wiring diagram
Does anyone know the circuit diagram for an ignition coil from a 2017-2020 NSX? I'm assuming it's going to be:
1. Trigger
2. Ground
3. Power
But I need to be sure before I wire up the harness.
Hitach part# IGC0094
Old 09-30-2021, 04:03 PM
Global Moderator
tech8's Avatar
Default Re: 2017-2020 NSX Ignition coil wiring diagram
The wiring from the harness connector's terminal side is:
1 - IG (IGN01) from junction connector (power)
2 - PG (Coil) from ground G101
3 - IGN01 from PCM
This would match with the way you listed for the ignition coil.
Old 09-30-2021, 08:22 PM
3 - IGN01 from PCM
Thank you for the response. I found a diagram for them, which coincides with what you've said. However, it does not match the way I listed. Regardless, both you and the service manual have provided the proper wiring.
Looking forward to wiring these up!
94WhtLytng
11-20-2006 07:47 PM
DigitalTracers
06-16-2005 03:57 PM
Revi
06-24-2004 08:40 AM
H22Si
05-28-2003 10:45 AM
b16 matt
04-30-2003 07:09 PM
Quick Reply: 2017-2020 NSX Ignition coil wiring diagram
