Welp... my radio gives an "Err 3" code.
Old 09-24-2002, 07:31 PM
skafia's Avatar
Default Welp... my radio gives an "Err 3" code.
My battery got disconnected and I tried to enter in the radio code but I couldn't get it right. Tried 3 times and now it reads "Err 3." Anyone know how to fix this? Thanks.
Old 09-24-2002, 07:32 PM
Dave-ROR's Avatar
Default Re: Welp... my radio gives an "Err 3" code. (skafia)
wait an hour (well, I think it's an hour)
Old 09-24-2002, 07:36 PM
ZygSpeed's Avatar
Default Re: Welp... my radio gives an "Err 3" code. (Dave-ROR)
Either that or you'll have to take it to a Honda/Acura dealer.
Hopefully the 1 hr wait will do it.
Old 09-24-2002, 07:38 PM
Ferrell's Avatar
Default Re: Welp... my radio gives an "Err 3" code. (Zygspeed)
disconnect the battery again and wait a few minutes. Worked for me on the geeser a few weeks ago.
Old 09-24-2002, 08:04 PM
Dave-ROR's Avatar
Default Re: Welp... my radio gives an "Err 3" code. (Ferrell)
lol yeah that would probably work too
Old 09-24-2002, 08:05 PM
vtec.dc2's Avatar
not exactly sure, but you can only enter the code certain amount of times before it locks - theft prevention or something.. call acura - see what they say
Old 09-24-2002, 08:12 PM
Ferrell's Avatar
Default Re: Welp... my radio gives an "Err 3" code. (vtec.dc2)
call acura, have VIN # ready
[Modified by Ferrell, 12:12 AM 9/25/2002]
Old 09-24-2002, 08:18 PM
brownman72000's Avatar
Yo man. This has happened to me so many times. Disconnect the battery and pump the brake until it you feel it tighten up. Wait few seconds, connect the battery again. Then put the key in the ignition and put it to accessory. You will be given a chance to enter the code again. Once again, you will get 3 attempts for error 3 comes up. To put the code in correctly, push the number of the corresponding code number. For instance...My code is 1555. So, I would push the 1 button once, then push the 5 button 4 times in a row. Thats how you do it. I couldnt figure it out for the longest time and it got annoying. There is no need to call Acura or anything else unless you got the code itself. Otherwise, this will work fine. Good luck!
Old 09-24-2002, 08:22 PM
New User
JDM nerbie's Avatar
people come into my dealer all the time with this problem. all i do is disonnect the positive and negative terminals on the battery. touche the two cable together for about 10-15second. reconnect it and punch in the code. that should work.
Old 09-24-2002, 08:37 PM
skafia's Avatar
Default Re: Welp... my radio gives an "Err 3" code. (JDM nerbie)
Okay, I will try that tomorrow, thanks guys! Wait, I don't even listen to any music in the R. I just listen to the car, it's awesome
Old 09-25-2002, 04:53 AM
BlackAckeR's Avatar
Default Re: Welp... my radio gives an "Err 3" code. (brownman72000)
...Disconnect the battery and pump the brake until it you feel it tighten up. Wait few seconds, connect the battery again. Then put the key in the ignition and put it to accessory. You will be given a .... Good luck!
This sounds odd, what the heck do the brakes have to do with the electrical system!?
Old 09-25-2002, 05:33 AM
Rory Breaker's Avatar
Default Re: Welp... my radio gives an "Err 3" code. (BlackAckeR)
I assume thats just a way he uses to measure how much time is needed for it to reset...
philibuster
Acura TSX
03-02-2011 05:20 PM
neoway
Acura TL, RL & ZDX
09-21-2010 10:30 PM
Forster Bittner
Audio / Security / Video
12-23-2005 09:37 PM
kehayov_jr
Acura TL, RL & ZDX
09-06-2005 07:13 AM
Stripped Honda
03-02-2003 10:14 AM
Quick Reply: Welp... my radio gives an "Err 3" code.
