Transmission "Notchy", Dealer Says Clutch is warn out?
Old 03-19-2004, 10:37 AM
onyx00's Avatar
Default Transmission "Notchy", Dealer Says Clutch is worn out?
Just wanted to get people's opinion on this.
Took my car to the dealer for some warranty work and mentioned my transmission was feeling notchy. They say it is because my clutch is worn and it is not disengaging properly.
I have not felt any slipping (tried putting the car in 5th gear and letting the clutch out and it stalled right away, so friction material seems fine).
The car only has 40K on it; is this not a warranty item? I could understand the friction material getting worn, but the do other parts really wear on the clutch?
They said $1400 to replace the clutch and resurface the flywheel.
What does everyone think?
P.S. warn = worn
Old 03-19-2004, 10:48 AM
RTW DC2R's Avatar
Im gonna call BS. If the clutch feels fine, then its not a clutch problem. If the clutch isnt disengaging properly or fully, I think youll be able to tell and itll probably feel like crap.
$1,400!! damn.
Old 03-19-2004, 11:06 AM
H-T Order of Merit
nsxtasy's Avatar
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? (onyx00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 &raquo;</TD></TR><TR><TD CLASS="quote">The car only has 40K on it; is this not a warranty item?</TD></TR></TABLE>
Replacing the clutch due to wear is not covered under the warranty.
However, I would get a second opinion before doing so.
Old 03-19-2004, 11:07 AM
jdmjay04
Guest
Posts: n/a
1400$ dollars wth . A good clutch and flywheel setup + installation should be about 800-850
Old 03-19-2004, 11:25 AM
Blazeone's Avatar
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? (jdmjay04)
dealers are fucktards, they told me my whole clutch was gone and it was going to cost me $1500 to fix becuase the clutch disk exploded. I buy a new spoon clutch/fw/pp and find out that the spring on the pressure plate fell out and my clutch disk and flywheel wre absolutely fine.
To acura service
Old 03-19-2004, 11:49 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 &raquo;</TD></TR><TR><TD CLASS="quote">They said $1400 to replace the clutch and resurface the flywheel.
What does everyone think?</TD></TR></TABLE>
**** dealership service centers -- that's what I think.
Old 03-19-2004, 11:51 AM
H-T Order of Merit
nsxtasy's Avatar
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? (Mugen Mike)
I think good dealers - and there are are some VERY good dealer service departments - are great. And bad dealers... are bad.
Now, maybe we could get back to helping Chris with his transmission/clutch question, instead of hijacking the topic to slam dealers?
Old 03-19-2004, 11:54 AM
SamC's Avatar
maybe just change the tranny fluids if you haven't.
Old 03-19-2004, 01:43 PM
onyx00's Avatar
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? (SamC)
The dealer explained better when I picked up the car.
According to the "top mechanic" there he believes one side of the friction plate is wearing more than the the other side and that the side that is wearing more is dragging, causing the notchy feeling.
This kind of sounds like crap to me. Why would one side of the friction plate wear more than the other?
Old 03-19-2004, 02:07 PM
[HrZn]4life's Avatar
I agree get a second opinion somewhere. Is it notchy in every gear or just certain gears. Also that price is insane....definitely look somewhere else b/c like someone else said a brand new clutch, flywheel resurfacing and labor is around 800.
Old 03-19-2004, 02:28 PM
H-T Order of Merit
nsxtasy's Avatar
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? ([HrZn]4life)
Some dealers and shops do a lot of internal transmission work, and some don't. Make sure you get your second opinion from a place that does. Like maybe that place that helped you with your brake problem.
Old 03-19-2004, 02:51 PM
New User
NSX Bob's Avatar
First thing I would do is replace the transmission fluid and see how it feels. Just because a stealership says it doesn't make it true.
Old 03-19-2004, 02:55 PM
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? (Type R Bob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Bob &raquo;</TD></TR><TR><TD CLASS="quote">First thing I would do is replace the transmission fluid and see how it feels. Just because a stealership says it doesn't make it true.</TD></TR></TABLE>
I agree, change the tranny fluid first...and make sure to use HG tranny fluid.
Old 03-19-2004, 04:09 PM
mikestypeR
Guest
Posts: n/a
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? (BlazeONE)
mine had the same thing ... then the clutch disc shattered and ruined the tranny... now i have to rebuild it... so word of the wise dont drive it anymore till you know what it is ... or you will be rebuilding like me
Old 03-19-2004, 04:14 PM
RTW DC2R's Avatar
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? (mikestypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeR &raquo;</TD></TR><TR><TD CLASS="quote">mine had the same thing ... then the clutch disc shattered and ruined the tranny... now i have to rebuild it... so word of the wise dont drive it anymore till you know what it is ... or you will be rebuilding like me </TD></TR></TABLE>
? how did a broken clutch disc destroy the tranny?
Old 03-19-2004, 04:24 PM
sackdz's Avatar
Its a pretty common problem. Pressure plate spring seats can loosen causing the drag. Could also be a cracked disc/ dislodged spring. Replace the disc/pp.
Modified by sackdz at 9:02 PM 3/19/2004
Old 03-19-2004, 04:55 PM
Misfit's Avatar
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">Its a pretty common problem. Pressure plate spring seats can loosen causing the drag. Could also be a cracked disc/ dislodged spring. Replace the disc/pp.
Enough drag to make shifting notchy is not nessesarily enough to feel the clutch slipping.</TD></TR></TABLE>
same thing happened to me.. I ended up with an Exedy clutch and Toda flywheel
I gave up on dealerships long ago..
Old 03-19-2004, 08:35 PM
mikestypeR
Guest
Posts: n/a
Default Re: Transmission "Notchy", Dealer Says Clutch is worn out? (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
? how did a broken clutch disc destroy the tranny?</TD></TR></TABLE>
well i was told that the clutch broke but it was still slightly drivable "i had know idea it was busted" dont ask hahah then this ate away at all the syncros then fucked the input shaft and some other shaft and because all those parts got fucked they in return helped **** other parts such as seals and some other **** all i know is the tranny is fucked
Old 03-19-2004, 08:41 PM
onyx00's Avatar
Hopefully that doesn't happen to me.
How hard is it to install a new clutch yourself?
Old 03-19-2004, 09:08 PM
Bbasso's Avatar
Ken, I would have to slam every Dealer I have ever been to in my life
Onyx00
Please get a second opinion, from a tranny shop.
Change the MTF if you don't mind.
As for D I Y, if you can spare yourself the headache then pay to have it done- maybe a friend who works for a big shop that can do side work and use the lift IF your going to do it yourself, leave 3 days for your first tempt if on the floor.
Pay cash maybe 200-300 for labor.
And clutchcityonline.com has great prices and service.
Old 03-19-2004, 09:10 PM
RTW DC2R's Avatar
well i was told that the clutch broke but it was still slightly drivable "i had know idea it was busted" dont ask hahah then this ate away at all the syncros then fucked the input shaft and some other shaft and because all those parts got fucked they in return helped **** other parts such as seals and some other **** all i know is the tranny is fucked </TD></TR></TABLE>
haha oh ok I thought you just meant that when the clutch disc broke it ended up breaking the tranny
globy123
11-29-2007 11:21 AM
threesixes
10-05-2007 11:42 PM
zach1288
16
05-09-2007 05:57 AM
SoullessJapaneseMachine
15
02-22-2007 10:16 PM
Brett
02-12-2003 04:26 PM
Quick Reply: Transmission "Notchy", Dealer Says Clutch is warn out?
