Stronger wheel studs and lug nuts? Suggestions please.
Old 01-04-2003, 04:04 PM
Paragraph Alert
ActiveAero's Avatar
Default Stronger wheel studs and lug nuts? Suggestions please.
I've having problems with my stock wheel studs and lug nuts. I've already rung off one stud and had it replaced. Now several more are getting tight as I try to loosen them. It is keeping me from changing out my rims and rotating my tires for fear of breaking more off. I'm thinking of just replacing all of them with a stronger set and some good lug nuts to compliment them. Any suggestions?
Old 01-04-2003, 04:26 PM
acuracing's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (ActiveAero)
I broke off so many of the studs. Honda should realize they are a problem. I did go ahead and change all of mine before. It wasn't too expensive and it was peace of mind that I could "start over."
Old 01-04-2003, 05:26 PM
Global Moderator
Reid's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (George Knighton)
Recently replace mine w/Skunk2 studs and Daiyama lug nuts.
It's working fine so far, although I have to admit that I have heard of people seizing the Skunk2 studs.
The problem I've been hearing isn't seizing, but rather the Skunk2 studs sheering off.
Old 01-04-2003, 06:25 PM
purplehazek4's Avatar
spoon makes wheel studs as well and they're 10mm longer.
about eight bucks a piece it's not too bad
Old 01-04-2003, 07:28 PM
FSTASNTZ's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (purplehazek4)
ARP...
Jason
Old 01-04-2003, 07:34 PM
Global Moderator
Reid's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (FSTASNTZ)
ARP...
This is what I use.
If I were you, George, I would remove the Skunk2 studs ASAP and install ARP units.
Old 01-04-2003, 09:31 PM
Frosty_spl's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (Reid)
A lot of guys run moroso ones, i dont remember the thread pitch and such, but they are the same as the skunk ones and cost around 8 bucks for 10. ( i think, they are a whole lot cheaper anyway).
Old 01-04-2003, 09:40 PM
Wai
ProFunction/GT Motoring
Wai's Avatar
I think the Skunk2 studs are the same as the Z-speed ones. If yes that I would not recommend it..... Here are mine:
I ended up buying the Spoon ones (10mm longer) and have been using anti-seize. No problem so far (~3 yrs). In your case, I think using anti-seize should solve the problem.
Old 01-04-2003, 09:43 PM
Tweakmeister's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (Wai)
how many of you put anti-seize on the studs?
Old 01-04-2003, 10:23 PM
jeff652's Avatar
Read:
http://www.hybridautomotive.com/tech/arp_studs/
HTH
Jeff
Old 01-04-2003, 10:29 PM
If You Slip You Die's Avatar
ARP... :
Old 01-05-2003, 12:06 AM
TurboITR's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (lilxjoker)
skunk 2s are garbage get rid of them while you still have a choice - i used arps (for a camaro) and they work great - i have had 0 problems with them
Old 01-05-2003, 12:35 AM
Downey's Avatar
ARP.
Old 01-05-2003, 04:31 AM
rolow's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (TurboITR)
MY skunk2 almost left me stranded at the track
Old 01-05-2003, 10:54 AM
Honda318dx's Avatar
I raced at VIR and Summit w/ skunk2 studs, they didn't break... Also have changed the tires several times.. granted, I havn't heard much good stuff about them, but mine havn't broken yet...
Old 01-05-2003, 02:16 PM
magic hat #9's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (Honda318dx)
use permatex anti-sieze with oem studs & nuts. you are breaking studs due to: human error or corrosion causing binding between the stud/nut. my lugnuts go on and off like butta'. try anti-sieze before you blow money on aftermarket.
Old 01-05-2003, 03:10 PM
Moderator
chad's Avatar
i'm going with junk2's too....and they aren't junk just say that cause...well i have a hatchcrapper
Old 01-05-2003, 03:37 PM
specie's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (chad)
where is the cheapest place to get a set of ARP?
Old 01-05-2003, 06:25 PM
kkim's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (Tweakmeister)
very good question. with anti-seize and a torque wrench I would think your problem should disappear.
But then I see very knowledgable people here posting that they have been having the same snapping problems. Care to enlighten us on what the problems are with snapping studs? I assume you guys are using AS and a torque wrench, so is this a racing fatigue problem?
[Modified by kkim, 4:26 PM 1/5/2003]
Old 01-05-2003, 06:31 PM
jond's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (kkim)
Stupid question. Will motor oil do the same thing as the fancy anti-seize stuff?
Old 01-05-2003, 08:11 PM
smokin rubber's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (jond)
no motor oil is not the same,. got to your local auto parts store and buy some anti-size, it's in a little squeeze tube and is only a dollar or two. It's good for spark plugs too.
Old 01-06-2003, 05:34 AM
Jack Black's Avatar
Stupid question. Will motor oil do the same thing as the fancy anti-seize stuff?.
Problem with motor oil is that it may burn off when the brakes heat up. Anti-seize is made with a metallic lubricant in addition to the petroleum-based lube, so it won't burn off. In fact, my dad used to have a type of anti-seize that was a powder, and it worked just as well as the traditional paste type. Main problem with it was that it got all over everything.
Old 01-06-2003, 07:03 AM
jond's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (itr01-0851)
Damn. Glad I asked
Old 01-06-2003, 07:09 AM
Willard's Avatar
anti-seize and a torque wrench (used correctly) = safe studs all of my life.
Old 01-06-2003, 07:14 AM
ZygSpeed's Avatar
Default Re: Stronger wheel studs and lug nuts? Suggestions please. (Willard)
antisieze
"protection"
Quick Reply: Stronger wheel studs and lug nuts? Suggestions please.
