rear 5lug hub part #
Old 09-16-2010, 08:13 AM
I'm not Rick!
rick_rabies's Avatar
Default rear 5lug hub part #
does anyone have a part # for this.
the hub/wheel bearing deal that bolts onto the rear trailing arm via 36mm nut and 3-4 other nuts on the backside of the trailing arm
i appreciate it
Old 09-16-2010, 10:58 AM
H-T Order of Merit
nsxtasy's Avatar
Default Re: rear 5lug hub part #
Click on the diagrams for part numbers. (You could have looked this up yourself on Delray Acura's website, you know.)
Old 09-16-2010, 11:05 AM
I'm not Rick!
to bolt this on the original gsr 4lug trailing arm
would i just need #s 2 and 44-45? and the other parts i can reuse?
i appreciate it Nsxtasy
Old 09-16-2010, 02:19 PM
audiko4's Avatar
Rear wheel and hub part # 42200-S03-C51
heres a good write up on what needs to be done to convert regular integra trailing arms to 5 lug type r.https://honda-tech.com/forums/suspension-brakes-54/5-lug-conversion-using-4-lug-spindles-front-rear-1978033/ The rear trailing arms on a type R have a longer spindle for the bigger 5 lug hub.
Old 09-17-2010, 03:58 AM
I'm not Rick!
ahh that makes it more clear thank you kind sir
kwae
Honda CR-V & Element
03-13-2016 08:35 PM
JJ's civic
21
08-30-2006 02:18 PM
Type V
Suspension & Brakes
14
05-08-2006 04:57 PM
SE7EN3S
14
10-23-2005 06:16 PM
Quick Reply: rear 5lug hub part #
