Part Numbers Needed y0 ;)
Can anybody get me the part numbers for these following items???
B-series valve seals
P72 oil pan gasket
Valve cover gasket
spark plug seals
Thanks in advance y0
P72 oil pan gasket
Valve cover gasket
spark plug seals
Re: Part Numbers Needed y0 ;) (sackdz)
My point exactly <FONT SIZE="8">y0</FONT>
You gotta add the part numbers, which is why I need them.
Also search by description is not working either
Re: Part Numbers Needed y0 ;) (Gravity)
I can get part numbers off of AAP just fine. I wont tell you the trick because then they will fix it and I wont be able to do it anymore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravity »</TD></TR><TR><TD CLASS="quote">IM Len
he should be able to get you the numbers you need y0! (had to keep the post going)</TD></TR></TABLE>
I already did that y0. I didnt ask him for the part#'s, I asked him for prices y0. He must be out hunting already.
Re: Part Numbers Needed y0 ;) (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">I can get part numbers off of AAP just fine. I wont tell you the trick because then they will fix it and I wont be able to do it anymore.</TD></TR></TABLE>
Then hook it up for me bro(I mean y0)
Re: Part Numbers Needed y0 ;) (Gong Show)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gong Show »</TD></TR><TR><TD CLASS="quote">Can anybody get me the part numbers for these following items???
12210-PZ1-003 Int. Valve Stem Seal A (ARAI) $3.79 (x8)
or
12210-PZ1-004 Int. Valve Stem Seal A (NOK) $0.60 (x8)
12211-PZ1-003 Exh. Valve Stem Seal B (ARAI) $3.79 (x8)
or
12211-PZ1-004 Exh. Valve Stem Seal B (NOK) $0.60 (x8)
P72 oil pan gasket
11251-P30-004 Oil Pan Gasket $18.42
Valve cover gasket
12341-PR3-000 Valve Cover Gasket $ 8.10
spark plug seals
12342-PG6-000 Spark Plug Grommet $ 1.76 (x4)
Thanks in advance y0 </TD></TR></TABLE>
or
or
P72 oil pan gasket
Valve cover gasket
spark plug seals
12210-PZ1-004 SEAL A, VALVE STEM $0.68 INTAKE each
12211-PZ1-004 SEAL B, VALVE STEM $0.70 EXHAUST each
12342-PG6-000 GASKET B, HEAD COVER $2.03 spark plug valve cover seals
12341-PR3-000 GASKET, HEAD COVER $7.74 See Note
12341-PR4-A00 GASKET, HEAD COVER $7.74 See Note
11251-P30-004 GASKET, OIL PAN $20.56
Note: Not sure which is correct for valve cover gasket, the page was unclear and showed both LS and VTEC motors with the same illustration number.
EDIT, PR3 is correct for valve cover gasket.
erikiksaz1
13
10-07-2004 06:21 AM
Dirt
05-03-2003 07:13 PM
