need help with wire harness
Re: need help with wire harness
If im not mistaking I think the jdm motor is obd1 so you should be able to use your harness get a gsr ecu and run a wire from ecu to vtec
(easiest way) use a 96-99 usdm engine harness and run the 2 vtec wires from the gang plug on the passenger shock tower to the ecu and use a chipped p28 /
can i use a p30 ecu and just use a jumper harness to the jdm harness to convert it obd1 to obd2.
and if works can i pass state ref like that?
Kirk@SyndromeAuto
12-13-2006 05:24 PM
