Milling head questions with toda Bs.
Old 10-30-2002, 08:23 PM
Mad Cow Disease's Avatar
Default Milling head questions with toda Bs.
Hi, ive got a b18c-5 and have installed the toda spec Bs with +2 and -2 cam degrees. My head gasket went out yesterday, and it turns out it is a warped head. I plan on milling the head to get rid of the warpage and increase the compression. My question is what is the most I can mill the head, and is there a certain amount that you reccomend.
thanks
tim
Old 10-31-2002, 10:27 AM
Shark Tank's Avatar
Default Re: Milling head questions with toda Bs. (tmc racing)
i would say no more than 10 thousandths and use a stock head gasket
Old 10-31-2002, 10:36 AM
sackdz's Avatar
Default Re: Milling head questions with toda Bs. (CART fan)
.020" would be good, and add a Mugen gasket. You should be around 11.8:1 then
[e]Assuming you have stock internals
[Modified by sackdz, 2:42 PM 10/31/2002]
Old 10-31-2002, 10:39 AM
sneakychaos's Avatar
Default Re: Milling head questions with toda Bs. (sackdz)
for some reason I am thinking .060 is the MOST you can go on the head - not necessarily what you WANT to go. I wanna say .030 off is about a 37cc chamber.
Take all of that with a grain of salt - thats just pure guesses trying to remember off the top of my head.
Old 11-04-2002, 02:19 PM
Drag R's Avatar
Default Re: Milling head questions with toda Bs. (sneakychaos)
with those big *** cams the most you could go before valve clearance issues is about .020 thousandths.....
thats pushing it, at least for me....
good luck
Nick
Old 11-04-2002, 02:27 PM
type r 01-1063's Avatar
Just out of curiosity. What are the causes of a warped cylinder head?
Old 11-04-2002, 07:37 PM
Drag R's Avatar
Default Re: Milling head questions with toda Bs. (type r 01-1063)
From the motor constantly overheating...
Old 11-09-2002, 09:29 PM
Michael Delaney's Avatar
10 thou. max = factory spec tolerance
Old 11-09-2002, 09:34 PM
splitime's Avatar
clay for clearance, then figure out how much room you have.
Old 11-10-2002, 08:12 AM
Default Re: Milling head questions with toda Bs. (Drag R)
Went with .020, no problems.
[Modified by tmc racing, 5:12 PM 11/10/2002]
Old 11-12-2002, 12:41 PM
JDM_ITR's Avatar
would 10 thousandths be good for my set up?
B18 block
B16 head
CTR pistons
B16 cams (getting CTR cams soon)
Leventis
04-20-2005 10:19 PM
MEANB18
08-03-2003 03:21 PM
TypeR0149
02-24-2002 07:12 AM
slowcivic
09-27-2001 10:47 AM
slowerthanu
07-09-2001 01:31 PM
Quick Reply: Milling head questions with toda Bs.
