Head Decking Question
Old Sep 27, 2001 | 05:10 AM
slowcivic's Avatar
New User
Default Head Decking Question
How much material ( in mm. ) is generally taken off a GSR Head when Decked and will it effect Piston to Valve Clearance? I plan to use Toda C Cams with a stock GSR Head Gasket. Thanks.
Old Sep 27, 2001 | 05:57 AM
slowcivic's Avatar
New User
Default Re: Head Decking Question (slowcivic)
In my case, would .5mm of material taken off be too much?? Thanks
Old Sep 27, 2001 | 09:58 AM
martini's Avatar
.5 is quite a bit. The only way you can really be sure, is to have your engine clayed. And run stiffened springs to be safe.
Old Sep 27, 2001 | 10:12 AM
sgT's Avatar
sgT
Default Re: Head Decking Question (martini)
The most I would take off a head with spec Cs is .005"
And run a stock head gasket.
Old Sep 27, 2001 | 10:47 AM
rainforest's Avatar
Default Re: Head Decking Question (sgT)
listen to sgt dont deck it too much. there is only 7mm diff between the b16a and the b18a block so basiclly just deck to what you need. it should only be like .005
Joker_God
12
Nov 30, 2009 01:34 PM
lv6l
Nov 21, 2004 02:37 PM
b18prl
Mar 4, 2003 11:17 PM
Mad Cow Disease
Nov 12, 2002 12:41 PM
slowcivic
Sep 27, 2001 04:04 PM
