bad o2 sensor?
Old 08-28-2002, 05:05 AM
neumonik's Avatar
Default bad o2 sensor?
Background of problem:
If the car sits for an extended period (enough for it to REALLY cool down), when I start the car everything is fine for a while but then after about 5 to 10 minutes the check engine light comes on. I checked the code and it's a code for an o2 sensor. Now if I shut the car off for a few seconds and crank it back on... everything is fine for the rest of the day. The code is still there if I jump the ecu, but I have no check engine light.
On really hot days if I let the car sit for 10 minutes ideling and then drive... I get no check engine light. Could this be the sensor going bad??
Thanks!
Frank
Old 08-28-2002, 10:03 AM
neumonik's Avatar
Default Re: bad o2 sensor? (neumonik)
up
Old 08-28-2002, 11:02 AM
JPP
JPP's Avatar
Do you have a stock exhaust system?
What code # are you getting ?
Old 09-03-2002, 06:42 AM
b16wannaride's Avatar
Sometimes you may need to use an On Bboard Diagnostic system (that plugs in under your steering) to clear the code/s completely. However, I think more and likely your o2 sensor is going bad though.
slim689
04-19-2007 10:55 AM
Mad Money
09-27-2006 08:22 AM
raphael
08-08-2006 05:44 PM
bumthology
10-05-2004 03:18 PM
yellowcrx13
01-21-2004 03:41 PM
Quick Reply: bad o2 sensor?
