Aftermarket wheel, srs light? inspection?
i have a brand new spoon wheel that i wanted to put in my ITR, but before i did i wanted to make sure that there was a way i could still pass inspection when the time comes. Once i take out my stock wheel and put the spoon wheel in, the srs light will be on. If i keep my pass. airbag system in can i just install my stock ITR wheel and reset the srs light and pass inspection, or am i oversimplifying the process? I know a lot of people put aftemarket wheels in 96+ cars. Any advice will help...
Re: Aftermarket wheel, srs light? inspection?
Someone else will post further details, I'm sure. But I see no reason why what you propose won't work. The only problem is that you cannot sell your stock ITR wheel. Then again, it is best not to sell one's stock parts when modding - for possible later resale.
Don't judge or question
You don't need to put your stock wheel back in to turn the SRS light off. If you want to run the Spoon steering wheel without the SRS light on you will need to get a 2.2 ohm resistor to simulate the airbag. Then you will need to reset the light using the instructions below.
<pics>
<pics>
FYI - 'SCS Service Connector' = Paper clip
What state is your emissions testing? As long as your check engine light isn't on, srs may be overlooked because it's not emissions based, but on the safety aspect, it should pass. Remember, if your oem steering wheel came with horn buttons, your aftermarket wheel should have a visble horn pad on the wheel as well-state inspectors look for that. good luck
this man is always right! ive dont it..it works 100% if you have any questions on it pm me. i did it on a OEM JDM Non srs wheel..and the horn is fairly erasy to get working also
thanks for the help, im located in CT and emissions does not look for this kind of stuff, only exhaust and evap issues, so it looks like i can pull the airbag system on both sides if i wanted. Someone may want to clear this up but someone told me if i dont have the airbag system on the driver side the pass. side airbag wont work so i should remove it anyways...
thankss. Is there a way to simulate both airbags, i was planning on taking both airbag systems out without have my srs light on
If you're removing the airbags, why not just remove the SRS light from the gauge cluster, problem solved. Going through and putting in a resistor to "simulate" the airbags seems kind of pointless, when they're not even there.
If you just pull the bulb out from behind the cluster will they know at Inspection when they hook it up to there computer anyway?
after startup..aka working normally
View My Video
What are they plugging in at your "inspection"? The only thing any state inspection has ever plugged in would be an OBD-2 port scanner, and that doesn't read SRS codes, its emissions related.
Where do you put the resistor? This is how I did my ITR non SRS steering wheel. http://www.team-integra.net/sections...ArticleID=1226
01-ITR
If you are removing the passenger airbag too, then you may as well remove the control module and wiring harness as well... and the cluster lamp too if you wish but it ain't going to lite without the module.
Now if you remove the ENTIRE SRS system, it will pass inspection, but you cannot just remove one component. All or nothing. I'm sure other states are the same.
CrackThatTec45
09-04-2009 07:51 AM
servion
01-14-2002 01:54 PM
