ABS Light?
ABS Light?
Searched many times and found many things..
Just wondering if our ABS setup is the same as all other integra's and all you have to do to reset the ABS is pull the ABS2 fuse? Just replaced my clutch and now after about 500 miles on it, the ABS light popped on.
I didn't take anything off plug wise. Didn't remove the ABS sensor, so I'm thinking it just need's to be reset? Thanks for the help in advance..
Re: ABS Light? (DC231_01)
i've had abs codes for the longest time and resetting the ecu wouldnt clear it. it turns out after reading the helms, abs codes are stored in an eprom on the abs computer. the way to reset it is to jump the scs, hold the brake, turn ignition to on, wait for abs light to turn off release brake, wait for abs light to turn on then brake again and it should be cleared. if the codes pop up again then you know you have a problem
Re: ABS Light? (hypeR speed)
So it is differant. That's what I thought, but I didn't have anyone to confirm it. Thanks for the help, me and my trusty paper clip are on a mission now..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypeR speed »</TD></TR><TR><TD CLASS="quote">i've had abs codes for the longest time and resetting the ecu wouldnt clear it. it turns out after reading the helms, abs codes are stored in an eprom on the abs computer. the way to reset it is to jump the scs, hold the brake, turn ignition to on, wait for abs light to turn off release brake, wait for abs light to turn on then brake again and it should be cleared. if the codes pop up again then you know you have a problem</TD></TR></TABLE>
almost sounds like an old school NES Contra cheat code everyone remembers
