2 crank pulley timing marks?? *pic*
OK, I have the cams set to TDC, and cyl 1 & 4 set to TDC, and lined up the mark on the oil pump gear...timing belt is on and one of the marks points to the TDC mark on the lower timing belt cover, referenced by the pink arrows below. Im almost 100% sure I have it set correctly since all the other marks line up. But there is another mark on the crank pulley, about an inch to the left when looking down at the pulley, green arrow below. What is that mark for?
Ryan, who is getting so close to starting her up for the first time since JUNE!
Re: 2 crank pulley timing marks?? *pic* (RTW Ryan)
The mark you have it on is correct. The mark by itself signifies TDC and the 3 marks grouped together are for the ignition timing If I am not mistaken the middle one (the one u have the green arrow on) is 15 degrees which is what you want to set your distributor at
You're on the right track. The pink arrow is pointing to the TDC mark on your pulley. The green arrow is pointing to 16 degrees btdc. The 2 hash marks on either side are 18 degrees btdc and 14 degrees btdc.
Re: 2 crank pulley timing marks?? *pic* (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 »</TD></TR><TR><TD CLASS="quote">what the hell...how did you take a snap shot of that? i couldnt see those marks without a timing light.</TD></TR></TABLE>
OMG your not serious, are you? makes me thing soup boy not so smart these days
ToTriggerHappy
01-13-2011 06:31 AM
WannaHonda
05-06-2004 10:12 AM
