where is the temp. needle suppose to be?
i have a 94 ls 110k all maint. performed.
question: where is the temp needle suppose to be on my car?
where it is at now: it never passes the quarter mark. (cold side) sometimes even lower?. i guess its better than overheating but is something wrong?
Or is the car just run real cool?
so wher should it be?
Location: That's the wrong tone... I'm Skunk2 certified.
I noticed that my temps were a bit lower than normal when my thermostat went out. They were steady for the most part, but just a bit too low.
I'd just put in a new thermostat and gasket. Cheap insurance, especially if you think your gauge is off.
Re: (full Circling)
yea i think i may put a new thermo state and gasket in becuase it does not really stay steady at the 1/4 mark on the cold side.
thanks
thanks
* B A N N E D *
Re: (full Circling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by full Circling »</TD></TR><TR><TD CLASS="quote">I noticed that my temps were a bit lower than normal when my thermostat went out. They were steady for the most part, but just a bit too low.
I'd just put in a new thermostat and gasket. Cheap insurance, especially if you think your gauge is off. </TD></TR></TABLE>
it was probably stuck opened, when my thermostat was stuck opened, it takes FOREVER to get to normal operating temperature
Re: where is the temp. needle suppose to be? (gohonda)
my motor runs like 1/8 below half is something wrong lol? im not too much of a tech guy and cant identify a problem right away..
Re: where is the temp. needle suppose to be? (phish4709)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 »</TD></TR><TR><TD CLASS="quote">
^when mine is fully warmed up</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phish4709 »</TD></TR><TR><TD CLASS="quote">my motor runs like 1/8 below half is something wrong lol? im not too much of a tech guy and cant identify a problem right away..</TD></TR></TABLE>
You mean just like the pic above ^^ ? Totally normal.
An aftermarket thermostat may cause the temp needle to be alittle different than stock. The condition of your temp sending unit could cause variation also. You want the temp needle to be between 1/4 and 1/2. Too cold isn't good because your car may always run in open loop running off rich maps and vtec will be disabled, and too hot isn't good either for obvious reasons.
get a new thermostat from napa, its probably the oem one still in there.
My car did the same thing. Sometimes it would warm up, then while driving it would drop back down to cold.
Its a bad thermostat, change it and you should be square.
15 bucks for a thermostat, 10 bucks for radiator fluid.
Re: (tdgcgpgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdgcgpgsr »</TD></TR><TR><TD CLASS="quote">My GSR is stock and it's always been like that too... normal being at 1/4 (cold side) and it never goes higher.
Could the needle just be messed up? Because the car is fine.</TD></TR></TABLE>
the needle isn't messed up. you need a new thermostat.
Re: (iwantvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwantvtec »</TD></TR><TR><TD CLASS="quote">damn that picture is mad clear... what kinda camera?</TD></TR></TABLE>
nikon d50
nikon d50
so the consensus is i probably need a new thermostat... its staying open too long. i will do that in the next week or so then post up to see if it fixed the prob.
jimmy o.
21
01-29-2009 07:22 PM
