What refrigerant is used in a 95 GSR?
I believe its R-134a....can I get someone to confirm this.....
Re: What refrigerant is used in a 95 GSR? (furious94ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by furious94ls »</TD></TR><TR><TD CLASS="quote">Your correct, Go to any auto parts store and pick some up.</TD></TR></TABLE>
Re: What refrigerant is used in a 95 GSR? (patdemps)
refrigerant was changed supposedly around 94ish according to one acura tech, so the 2 times i had to inquire about it, the techs on the phone jus told me to check on the shock tower where i found a metallic sticker with the refrigerant code on it. u can check there as well.
H-T Order of Merit
Re: What refrigerant is used in a 95 GSR? (pdcdragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdcdragon »</TD></TR><TR><TD CLASS="quote">refrigerant was changed supposedly around 94ish according to one acura tech</TD></TR></TABLE>
The A/C in the '94 GS-R definitely uses R-134a.
im pretty sure my 95 gsr came from the factory with r-12 refridgerant (accorrding to my cheapo chiltons manual) however i need to get it recharged so ill have to take it somewhere to drain the r-12, before it is refilled with r-134a, i dont think you are supposed to add r-134a to r-12. Someone must have a helms manual for a 95 gsr that can answer tthis question
H-T Order of Merit
Re: (Sportmode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sportmode »</TD></TR><TR><TD CLASS="quote">im pretty sure my 95 gsr came from the factory with r-12 refridgerant (accorrding to my cheapo chiltons manual) however i need to get it recharged so ill have to take it somewhere to drain the r-12, before it is refilled with r-134a, i dont think you are supposed to add r-134a to r-12. Someone must have a helms manual for a 95 gsr that can answer tthis question</TD></TR></TABLE>
I can answer this question. The 1994 and later Integras all came with R-134a refrigerant, and NOT with R-12. I don't know about the '93 or earlier ones.
Your '95 definitely came from the factory with R-134a. If you have a Chilton manual that says R-12, it's wrong. (The factory manual is better and more reliable, anyway.)
Re: (nsxtasy)
my 95 uses R134a, as for draining R12, I don't think its as simple and draining it and putting in R134a. You have to "convert" the system, isn't R12 like more expensive than GOLD by NOW?!!!?
Re: (Black-LS)
they sell a kit to change it to 134, at any autoparts store! all 94 and up tegs came with r134a you can also tell by the threads on the fill caps, i cant remember which is which but one will have inside threads as well as the threads for the caps.
