weird buzzing sound at startup
everytime i start up my car there is a weird buzzing noise. then after a couple secs of buzzing its gone. my friend says it could be normal and it may be the ecu?? any ideas?
Re: weird buzzing sound at startup (l4 soldier)
Don't know what a fuel pump is? Hint - IT PUMPS THE FUEL . Just playin buckaroo. It's probably your ABS which will do that all the time. Under the assumption you don't know what ABS is it means ANTI LOCK BRAKE SYSTEM. If your car has that then I can almost guarantee to you that is what you hear. If you car has that and the sound is coming from the engine compartment(Thats the compartment your engine is in). Then it's nothing to worry about.
Re: weird buzzing sound at startup (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">Don't know what a fuel pump is? Hint - IT PUMPS THE FUEL . Just playin buckaroo. It's probably your ABS which will do that all the time. Under the assumption you don't know what ABS is it means ANTI LOCK BRAKE SYSTEM. If your car has that then I can almost guarantee to you that is what you hear. If you car has that and the sound is coming from the engine compartment(Thats the compartment your engine is in). Then it's nothing to worry about.</TD></TR></TABLE>
second that; it's your ABS system. Completely normal for an integra with abs. Have someone else start your car while you stand by your passenger side fender, by your engine, and you'll hear it clearly.
Re: weird buzzing sound at startup (DCcliffjumper2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCcliffjumper2 »</TD></TR><TR><TD CLASS="quote">
second that; it's your ABS system. Completely normal for an integra with abs. Have someone else start your car while you stand by your passenger side fender, by your engine, and you'll hear it clearly.</TD></TR></TABLE>
and i third that.. ABS system, bugs the **** out of people.. but oh well
Eluzion
04-11-2004 09:51 PM
integra7
05-23-2002 09:39 PM
