want to test with a diff distributor
Old 02-20-2011, 08:59 PM
Da9austinRacing's Avatar
Default want to test with a diff distributor
ok so my car gets no spark. i checked for current on those two connections that go to the distributor i only get current thru one connection... the smaller one..is that suppose to be like that?
so im thinking that its my distributor.( i have changed coil,rotor,cap,)so i want to test out by putting a distributor from my friends B18 GSR....but i have the B17 GSR.. is it fine if im able to check with his distributor or it wont work.
Old 02-21-2011, 05:52 PM
not his 410's Avatar
Default Re: want to test with a diff destributor
depends. if your b17 and the gsr both have obd1 distributors you can just swap them out no problem. but if it is a newer gsr engine its going to be obd2a/b both of which have different plugs for the wiring harness. or i could just save you the trouble and tell you your distributor is shot. it's not uncommon
Old 02-21-2011, 07:18 PM
egsleepercivic's Avatar
try swapping the igniter with your friends
Old 02-21-2011, 10:05 PM
Ok so the connections are good with one giving current
Old 02-22-2011, 11:51 AM
TOO MUCH TORQUE's Avatar
Default Re: want to test with a diff distributor
ignitor and coil is the main parts of the dizzy. you mentioned only coil
Old 02-28-2011, 10:03 PM
So the connections are good
DRAGANDB1
08-09-2018 06:19 PM
ILuvMyJdmDc4
11-27-2007 05:17 AM
ILuvMyJdmDc4
11-27-2007 04:43 AM
Quick Reply: want to test with a diff distributor
