Timing belt/Water pump labor costs
Old 05-28-2003, 12:45 PM
ShiftDown's Avatar
Default Timing belt/Water pump labor costs
I've already done a search on timing belts and pretty much got a lot of info on everything else I had questions on except for the average labor costs that shops around so cali charge for a timing belt/water pump install (for a 95gsr). So if anyone has gotten any good deals around the LA area can you post the labor costs and name of shop/location or a phone# if possible please. thanks
-david
Old 05-28-2003, 02:20 PM
Trac226's Avatar
Default Re: Timing belt/Water pump labor costs (Oki_Doki)
My shop usually does everything including parts for $500-600. This includes all associated seals and drive belts. Shop around for an honest mechanic, I would stay away from dealerships.
Old 05-28-2003, 04:36 PM
Blk95GSR's Avatar
diy man, its not that much.
Old 05-28-2003, 05:03 PM
grizoove's Avatar
Default Re: Timing belt/Water pump labor costs (Blk95GSR)
I got mine done at a dealership for 475 bucks.
Old 05-28-2003, 05:22 PM
95 integra's Avatar
Default Re: Timing belt/Water pump labor costs (grizoove)
The dealership around here just for the timing belt and water pump(not the 90k service) charge right at $400 with tax. I think its like $320 without the water pump.
Old 05-28-2003, 07:14 PM
M75
M75's Avatar
Here in Santa Monica they charge around $475-$600. I had my 94 ls done for $475 with a valve adjustment. The shop is called bvainc.net. Check them out online or call them up and ask for Manny.
Good luck.
Old 05-28-2003, 07:16 PM
GForceInteg's Avatar
Default Re: (M75)
Yeah guy timing belt and water pumps are cake. like a 1 hour job if you have a lift. if not then i dont know how long it will take but for what they charge its worth the time.
Old 05-28-2003, 10:04 PM
Trac226's Avatar
Default Re: (GForceInteg)
Hmmm, 1 hr is pushing it, but I guess it's possible. Air tools will help you out a whole lot as well. So if you're a do-it-your-selfer, you can just invest that $500 in tools.
Old 05-28-2003, 10:16 PM
Loveless's Avatar
Default Re: (Trac226)
the lift you guys spoke of: did you meant engine lift?
Old 05-28-2003, 10:28 PM
mickey513's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GForceInteg &raquo;</TD></TR><TR><TD CLASS="quote">Yeah guy timing belt and water pumps are cake. like a 1 hour job if you have a lift. if not then i dont know how long it will take but for what they charge its worth the time.</TD></TR></TABLE>
Yup, if you do it enough, and have all the right tools, it's a 1 hour job. My mechanic who did it for me told me it takes him 45 min. to replace the timing belt & water pump on my 94gsr. Dam bastard though charge me 2 1/2 hour labor was was still cheap. I bought all parts OEM from ahmotor.com
Old 05-28-2003, 10:31 PM
MachAF's Avatar
Default Re: (mickey513)
I'll probably be doing my water pump and timing belt in afew months, along with my sisters car too.
Old 05-29-2003, 02:17 AM
ShiftDown's Avatar
Thanks for the input fellas, I've thought about doing it myself but I don't have airtools and have never done a timing belt, I also don't have a lift. I don't have many friends who know more than how to change oil and simple stuff, none of them have ever tackled a timing belt or else I'd ask them to guide me through it. Oh well, now that I have an idea of how much it costs I'll know what to expect when I'm shopping around for prices. thanks again
-david
Old 05-29-2003, 02:36 AM
4DeepCivic's Avatar
Aslong as you have a shop manual, it's not as hard as you think. You just need a good set of sockets and wrenches. The only problem you might have is with the main pulley.
Old 05-29-2003, 09:19 AM
New User
psileepR's Avatar
Default Re: Timing belt/Water pump labor costs (4DeepCivic)
A shop out here in LB is asking for 395 installed for Timing Belt and water pump installed... so should i jump on that???
Old 05-29-2003, 07:55 PM
Default Re: Timing belt/Water pump labor costs (Civtek)
No meant whole car lift.
I will be doing a timing belt on my wifes car after she gets back from virginia.(has 59.9k i should have done it before) but anyway ill make another write up like the tenzo brake install.
http://www.gforceperformance.c...e.asp
Old 07-28-2003, 07:31 PM
EminemGSR's Avatar
Default Re: Timing belt/Water pump labor costs (GForceInteg)
How does $250 cash (no tax) for the belt and pump install without parts sound?
$400 total including the OEM pump and belt.
Modified by EminemGSR at 11:56 PM 7/28/2003
Old 07-28-2003, 08:36 PM
Rah Rah's Avatar
Default Re: Timing belt/Water pump labor costs (EminemGSR)
Man, you guys are getting raped with these prices. My mechanic (when I'm too lazy to do it myself) charges me about 150 to 200 bucks. Then again, it's a two-man operation with a tiny garage in the ghetto and he my father's friend of 20+ years . Anyway, like previously mentioned, you should try to do it yourself. Trust me, just do it. The more you work on the car yourself the more you'll understand how she works.
Old 07-28-2003, 08:58 PM
tegmaniac's Avatar
Default Re: Timing belt/Water pump labor costs (Rah Rah)
Anyone in the chicago area. I'll do a timing belt on an integra. labor $125+parts.
Old 07-30-2003, 06:42 PM
EminemGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rah Rah &raquo;</TD></TR><TR><TD CLASS="quote">Man, you guys are getting raped with these prices. My mechanic (when I'm too lazy to do it myself) charges me about 150 to 200 bucks. Then again, it's a two-man operation with a tiny garage in the ghetto and he my father's friend of 20+ years . Anyway, like previously mentioned, you should try to do it yourself. Trust me, just do it. The more you work on the car yourself the more you'll understand how she works.
If I had the time I would. I work 50-65 hours a week and barely have time to sleep and eat. So once again, is this deal alright? He quoted me at 3 hours labor for $250.
Old 07-30-2003, 07:16 PM
Lord Helmet's Avatar
Default Re: Timing belt/Water pump labor costs (ShiftDown)
for me:
timing belt & water pump= $150
labor= DIY & 1 hour
saving= $300+
with the extra $300 bucks I've saved I bought a set of new tires
can't beat DIY
Old 07-30-2003, 07:21 PM
Rah Rah's Avatar
3 hours labor for $250 is high. That's almost $85 per hour which is dealership rate. Shop around, you could find cheaper. My mechanic charges me that for parts and labor.
Old 07-30-2003, 10:37 PM
PandaBear's Avatar
I bring in my own parts and a local shop charge me $200, not very good work they spill coolant all over my hood. Dont even call me when they are done, etc.
You get to find a shop you are comfortable with and they will treat you better as they remember you
Old 07-31-2003, 07:09 AM
EminemGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rah Rah &raquo;</TD></TR><TR><TD CLASS="quote">3 hours labor for $250 is high. That's almost $85 per hour which is dealership rate. Shop around, you could find cheaper. My mechanic charges me that for parts and labor. </TD></TR></TABLE>
Yes I do agree that $85/hour is kind of high. Apprently, this is the lowest quote I've gotten so far out, with Acura wanting to charge $375 + tax (5 hrs labor) and my local shop wanting $300 + tax (4 hours). This latest quote I've gotten is from a honda tech who works out of his own garage.
Old 07-31-2003, 10:30 AM
phan's Avatar
call 323-465-1722 and ask for stacey. i've been going to him since i got my crx, both before and after my swap. their work is excellent, and is quite cheap compared to other prices i've seen. granted i've only been their for suspension issues and a valve adjustment ($55 for b16 adjustment w/ valvecover and sparkplug gaskets), i'm sure you'd be happy with his prices and service.
robert
Old 07-31-2003, 10:45 AM
EminemGSR's Avatar
Default Re: Timing belt/Water pump labor costs (phan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phan &raquo;</TD></TR><TR><TD CLASS="quote">call 323-465-1722 and ask for stacey. i've been going to him since i got my crx, both before and after my swap. their work is excellent, and is quite cheap compared to other prices i've seen. granted i've only been their for suspension issues and a valve adjustment ($55 for b16 adjustment w/ valvecover and sparkplug gaskets), i'm sure you'd be happy with his prices and service.
robert</TD></TR></TABLE>
Any suggestions for the New York area? Anyone? Bueller?
Quick Reply: Timing belt/Water pump labor costs
