temperature gauge goes down with hard acceleration
Old 02-20-2006, 02:42 PM
Mrs . M i c h a e l's Avatar
Default temperature gauge goes down with hard acceleration
i've been driving my 91 integra..with no real problems. i very rarely get on it since its stock and is just a daily driver. last night i was just crusing along and slowed down to about 40 and down shifted into 2nd and took off up to about 85. i noticed my temperature gauge went almost down to completely cold.
i have no problem with it doing this..its much better than overheating..but i'm really curious as to why and if this is a problem. other than that, there has been no temp problems. no overheating, my fan comes on when it needs to, etc.
Old 02-20-2006, 03:23 PM
EVLTEK's Avatar
does your car run colder then normal when driving around esp at night?
if so its your thermostat
Old 02-20-2006, 03:35 PM
Default Re: (EVLTEK)
i dont believe it does..if it does though, its so slightly that its barely noticeable.
thermostat was just changed recently with a brand new one as well.
Old 02-20-2006, 03:50 PM
ED7
ED7's Avatar
Default Re: (Stacked)
Since it it cold out, sometimes when you accelerate like that, you have lots of coolant circulation and its so cold out, it cools it down really fast and then your gauge shows colder. But i goes right back to warm right. This happened to me a couple times. Only when it just got to the the middle(warm) and then i accelerated then it dipped down a little. So its fine.
Old 02-20-2006, 03:54 PM
it was very, very cold last night. single digits.
i got off the throttle and the gauge came right back to operating temp. it didnt dip down a little though, it went down most of the way.
Old 02-20-2006, 04:08 PM
gixer00's Avatar
IT WAS PROB JUST YOUR CAR PULLIN IN ALL THE COLD AIR AROUND YOU I WOULDNT WORRIE ABOUT IT
Old 02-20-2006, 04:35 PM
mattcivic's Avatar
Default Re: (gixer00)
did u use and OEM thermostat? if not change it back anything other than stock sucks.
Old 02-20-2006, 04:40 PM
SlamminS85's Avatar
Default Re: (mattcivic)
maybe you dont have enough coolant... the coolant sloshes quickly away from the thermostat and it touches a cold metal part... who knows
Old 02-26-2006, 05:57 PM
Sturat77's Avatar
Agreed 100%. Aftermarket t-stats are notoriuosly bad. Use only genuine Honda.
Old 02-26-2006, 06:41 PM
Groove_D's Avatar
Default Re: (Sturat77)
Got the same problem, i got aftermarket thermostat too. Mind this it was -10 outside.
Weak!EG
02-16-2010 05:41 PM
boarding2008
02-01-2009 04:00 PM
in10ceCiviC
07-19-2007 12:10 AM
dizzzane
07-18-2007 12:40 PM
h46it
03-24-2002 05:16 PM
Quick Reply: temperature gauge goes down with hard acceleration
