Stripped Oil Pan
Old 02-19-2006, 10:56 AM
Ls InTeGrA RaCeR's Avatar
Default Stripped Oil Pan
Yeah so I know I'm a dumbass. I over tightened my drain plug and stripped out the threads on the pan. What's the best way to fix this so I'll stop leaking oil?
Old 02-19-2006, 11:34 AM
Gant's Avatar
get a oversized drain plug call like pepboys or any auto parts store and ask for one for ur car then thread that in it'll be tough threading it in but it'll create new thrads
Old 02-19-2006, 12:13 PM
Default Re: (Ba4)
Ok, I called Auto Zone and Advance Auto Parts and they only carry standard size plugs.
Old 02-19-2006, 12:30 PM
92integra-R's Avatar
Default Re: (Ls InTeGrA RaCeR)
i got a oil pan... what do you need?
Old 02-19-2006, 12:37 PM
loudassVTEC's Avatar
Get a tap and die set, and re-tap the pan threads, and rethread the plug. Or get a smaller drain plug, and use a heli-coil to thread that in.
Old 02-19-2006, 12:39 PM
JDMC-Kamel's Avatar
Default Re: Stripped Oil Pan (Ls InTeGrA RaCeR)
dude, make your headache go away, make life easier.
Replace oil pan.....trust me, it will keep those damn gremlins off your back...
Old 02-19-2006, 12:43 PM
Default Re: Stripped Oil Pan (JDMC-Kamel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMC-Kamel &raquo;</TD></TR><TR><TD CLASS="quote">dude, make your headache go away, make life easier.
Replace oil pan.....trust me, it will keep those damn gremlins off your back...</TD></TR></TABLE>
Yeah, he's right. For the price of a tap and die set, or the headache of choosing another bolt, and a heli-coil, you could just get a new pan, gasket, and drain plug, and call it a day.
Old 02-19-2006, 12:47 PM
Default Re: Stripped Oil Pan (loudassVTEC)
im tring to tell him but hes offline... i got a 90 rs oil pan with good plug. all i want is 45 dollars. he lives in zepherhills, i live in jacksonville. cant be that far away. for a price id deliver
i got the whole parts car, its the blue one
Old 02-19-2006, 12:50 PM
Uncle Willie's Avatar
Default Re: Stripped Oil Pan (92integra-R)
you can buy plugs called pan savers. Its got a wing nut on one end and a rubber groment thing on the other. Thats what we use at my work when we encounter a stripped pan.
Damn you must have cranked the hell out of that plug. Get a torque wrench for the next oil change.
Old 02-19-2006, 02:32 PM
Default Re: Stripped Oil Pan (RIP Indian Larry)
I'd really like to avoid removing my oil pan (I know its easy but I'm lazy). Anything else?
Old 02-19-2006, 02:57 PM
nitrofish420's Avatar
Short of replacing the pan, an oversized drain plug is your best bet, as stated earlier. Go to a NAPA or CarQuest or something, they'll have one.
Old 02-19-2006, 05:05 PM
Default Re: Stripped Oil Pan (nitrofish420)
Do they call it something else???? No one carries them????
Old 02-19-2006, 05:28 PM
Our NAPA stocks them, and they're just called oversize drain plugs.
Old 02-19-2006, 05:53 PM
shorto85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrofish420 &raquo;</TD></TR><TR><TD CLASS="quote">Our NAPA stocks them, and they're just called oversize drain plugs. </TD></TR></TABLE>
If they don't stock them they should be able to order it in from their warehouse
Old 02-19-2006, 07:41 PM
They let me pick
mrdeadman's Avatar
Default Re: (Ba4)
what are the torque specs for the drain plug?
Old 02-20-2006, 05:08 PM
Default Re: (mrdeadman)
Ok....turns out idiot I talked to the other day at NAPA didn't know his ****...called again today they had it for $2.59. Thanks Guys...Now I need torque Specs so I don't expletive this one up!
Old 02-20-2006, 05:18 PM
Global Moderator
tech8's Avatar
Oil pan torque spec. for most Hondas are 30 ft. lb.
But, I recommend to just finger tighten, no tools. Then use a box wrench or socket, and give 1/8 turn. Important: always use a new washer.
Old 02-20-2006, 05:26 PM
Global Moderator
tech8's Avatar
Default Re: (tech8)
BTW: Like mentioned in an earlier post, the first time threading the oversize plug will be tougher.
Old 02-20-2006, 06:47 PM
95 integra's Avatar
New pan.
Old 02-20-2006, 07:07 PM
They let me pick
mrdeadman's Avatar
Default Re: (tech8)
where can i get new washers?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">Oil pan torque spec. for most Hondas are 30 ft. lb.
Old 02-21-2006, 08:53 AM
bayareateg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">where can i get new washers?</TD></TR></TABLE>
At your local dealership, about 25 cents
Old 02-21-2006, 09:01 AM
four1one
Guest
Posts: n/a
Default Re: (bayareateg)
Why a new washer? I've changed my oil like 20 times and have never used a new washer... I haven't had any problem with it leaking or anything.
Old 02-21-2006, 09:22 AM
JERKthisDC2's Avatar
damn
Old 02-21-2006, 09:46 AM
Finger Lickin' good's Avatar
Default Re: Stripped Oil Pan (JERKthisDC2)
its not just a washer, its a crush washer. It will crush to make a better seal. They cost 5 cents each and every auto place has them.
ha we americans use something until it breaks. Japanese use and continue to check, which is why they dont break.
Old 02-21-2006, 11:40 AM
SIVEREKMETH's Avatar
pepboys makes an oversized rubber plug same thing happened to me on my gsr **** was leaking so i used the plug until i got it fixed the more you tighten the screw the more the rubber expands works perfect
Quick Reply: Stripped Oil Pan
