Steering rack adjustment - Best thing I ever did.
Old 05-22-2009, 10:31 AM
  #26
itslogz's Avatar
Default Re: Steering rack adjustment - Best thing I ever did.
Heres the pics of where the adjustment nut is located, edited the pics to make sure they are straight forward for people whos never seen this locknut.
Added alot of commentary in the pics so everything is clear of what the pictures are of, and what angles they are at so there is no confusion.
Old 05-22-2009, 11:33 AM
  #27
b20acura's Avatar
awesome pics, good info. i gota do this. but i think i still have to replace my tie rods. i jacked the car up to see if the wheels would move side to side and it did. so thats supposed to mean bad tie rods? which is what i was told.
Old 05-22-2009, 01:05 PM
  #28
PatrickGSR94's Avatar
wtf my car doesn't have any sort of cover like that.
I replaced my steering rack with a freshly-rebuilt unit (rebuilt with all OEM Honda parts) less than 2 years ago, so I'm going to assume that it doesn't need this adjustment.
Old 05-22-2009, 01:26 PM
  #29
TunerN00b's Avatar
I can't find if the OP posted what car he has, but since I see radius rods and no back half to the LCA, I'm assuming its a DA. Don't you have a DC Patrick?
Old 05-22-2009, 02:14 PM
  #30
oh snap! oops, guess I ASSumed it was a 94-01 And yeah my car is in my username
Old 05-22-2009, 07:48 PM
  #31
itslogz's Avatar
O **** I forgot, thought my car was in my sig.. Its my 1993 GSR. Should look the same for all 90-93 integra's and possibly others. Some may not have the cover? Dunno, hever looked at it on another integra/honda
Old 05-23-2009, 02:18 PM
  #32
TOO MUCH TORQUE's Avatar
thanks for the pictures! keep em up because i will be doing this in the.
i have a dc also, can anyone confirm this is similar to a DA?
Old 05-23-2009, 05:49 PM
  #33
itslogz's Avatar
it SHOULD be similar. Basically since youve seen what the locknut looks like, you can just search around under the car on the rack and look for that nut, is the best info I could tell you to find it on the DC since im not 100% sure.
Old 05-05-2010, 10:25 PM
  #34
gabebauman's Avatar
I'm having this very issue with my 93 Civic Cx hatch with manual steering rack. Steering wheel has some play in it that makes the steering feel sloppy at most speeds.
Old 05-06-2010, 12:34 PM
  #35
jomama's Avatar
this is good stuff.
Old 05-17-2010, 02:38 PM
  #36
nickelz34's Avatar
WTF ???!?!? weres the pics yo ? anyone else got pics of bolt location on their ride ? every other post on this topic in the forum is the same thing - everyone tells how to do it puts pics up than takes the pics off lator.
Old 05-17-2010, 05:20 PM
  #37
nickelz34's Avatar
oh yes they are there now GR8 ! thnx this is great
Old 05-17-2010, 06:00 PM
  #38
Katman's Avatar
We did this on my friends EG civic who had this very same problem (steering wheel shakes at high MPH); the shaking really shines at the road course I might add and totally kills your courage.
Well, he bought the Honda tool; took like 2 friggin weeks to get in. Got it last week. Wednesday night we tried seeing if this adjusting nut was the culprit. Upon loosening up the big nut, then checking the smaller inner (14mm) nut. I found that the inner nut within spec of the suggested 1/4 turn. This made me sad. But, his rack & pinion is shot anyways (outter boots are ripped and grease looks dried up). So instead of taking chances, we decided to pull the whole rack out and order up a rebuilt unit instead. Got the new rack in on friday and installed Saturday night. TOTAL HELL JOB with the motor in the car btw..but we managed. Test drove and shakyness eradicated!!!!!
We'll see what happens on May 28th as we're heading to Buttonwillow Raceway on that day.
I'll share photos I snapped of the rack and tool once I get the photos from my friends digy camera.
Old 05-19-2010, 11:17 AM
  #39
Katman's Avatar
photos as promised...
Old 05-19-2010, 11:29 AM
  #40
ZacCarter's Avatar
Anyone want to rent out there adjustment tool for a weekend? I don't want to pay 40 bucks for a tool I'm going to use one time. I'll pay for shipping etc.
If not they should adjust this at the alignment shop right?
Old 05-19-2010, 02:30 PM
  #41
tegradb7's Avatar
good stuff...had the same problem..wobbling on the freeway...hope this will fix it....
Old 05-26-2010, 09:41 PM
  #42
Rob.'s Avatar
good info !
Old 05-27-2010, 12:02 AM
  #43
dntnedvtec's Avatar
I was getting excited. I though I had found the cure..
Old 06-23-2010, 02:20 PM
  #44
rash's Avatar
Can anyone confirm if this works on cars with manual racks, or say, cars with power racks that have had their power steering removed w/ lines looped?
Just trying to find figure out if the adjustment tightens the flow of fluid, or if it's tightening the shaft coming from the steering column. It looks as if it's the latter, but I can't tell just by looking at the pics...
Old 06-24-2010, 05:39 AM
  #45
gabebauman's Avatar
I adjusted mine last night, (93 Civic Cx hatch with manual rack) and I can say it seems a little better. This is after I recently replaced both inner tie rods, got new tires, four wheel alignment and installed a new rack end bushing last month. The steering feels a bit stiffer., however the steering wheel still has some shudder in it on the interstate...but it's gone away at lower street speeds. You can definitely tell when the adjustment screw is bottomed out…it’s nearly impossible to turn the steering wheel. I backed the screw out to spec so it’s as adjusted as much as it’s gonna get.
Old 06-30-2010, 06:33 AM
  #46
rash's Avatar
That doesn't sound like fun. I can't understand why there is still shudder with all of the work you did. Maybe you need UCA bushings or ball joints?
Old 06-30-2010, 06:36 AM
  #47
gabebauman's Avatar
That's next on my list. I'm gonna double check that all the ball joint nuts are tight as can be, (pretty sure they are). I'm gonna inspect lca bushings as well.
Old 07-20-2010, 12:03 PM
  #48
xAgyex's Avatar
I just ordered the adjust tool. And will post pictures when i do the job. Thanks a lot people.
Old 07-20-2010, 12:29 PM
  #49
gabebauman's Avatar
I'll be changing both front wheel bearings sometime in the next two weeks. We'll see if that has any effect.
Old 07-20-2010, 01:44 PM
  #50
94rs-turbo's Avatar
seems pretty cool
Quick Reply: Steering rack adjustment - Best thing I ever did.
