Something snapped and car won't t move
Old 07-18-2015, 02:53 AM
Bigmo5328's Avatar
Default Something snapped and car won't t move
91 Acura Integra LS.... Been here before and I'm back again. Currently sitting in the car, But back to the question... Driving home from work this morning and was getting ready to make a turn went to pull off and something snapped and the car wouldn't go. Releasing the clutch and it sounds like something is grinding or flapping around. Press the clutch in and noise goes away. I can put it in gear but nothing happens. Any ideas?
Old 07-18-2015, 04:35 AM
B20VtecVillain's Avatar
Default Re: Something snapped and car won't t move
Sounds like a clutch/pressure plate/throw out bearing issue. I would pull the trans and take a look at everything
Old 07-18-2015, 09:48 AM
Technical Hero
HondaPartsHero's Avatar
Check your cv axles
Old 07-18-2015, 04:25 PM
wunfstgsr's Avatar
Clutch release bearing or pilot bearing most likely or clutch disc broke. Pull the trans and find the culprit.
Old 07-27-2015, 11:20 AM
Bigmo5328's Avatar
Turned out cv axle snapped..... Any recommendations on after market have to replace this almost once a year.... Others never snapped like this just started making alot noise when turning...
Old 07-29-2015, 11:20 AM
wunfstgsr's Avatar
look into a drive shaft level 0 replacement axle well worth the money!
Old 07-30-2015, 09:07 AM
egsleepercivic's Avatar
autozone has lifetime warranty but they are hit or miss... I have gotten bad ones straight out of the box from them
Old 07-30-2015, 05:47 PM
B_Swapped93's Avatar
used OEM or those part store ones I just went and complained if I got a bad one and they gave me a new one. DSS is fine too no warranty AT ALL tho... among k series guys they're not liked much but if you aren't driving hard etc it's fine.
Old 08-02-2015, 01:14 PM
tamboo's Avatar
just bought an empire driver's side, it even has the harmonic balancer thing like the honda part.
More Information for EMPIRE 801028
fminusmic
14
02-01-2022 05:07 PM
SuperTuner12010
11-27-2009 06:56 PM
CDUB321
10-29-2009 05:59 PM
Rhythmsnewsn
11-01-2007 03:32 AM
Lookinaround
17
06-14-2006 06:15 AM
Quick Reply: Something snapped and car won't t move
