rpm dipping and idle bouncing
Old 02-26-2015, 08:14 AM
b18egtheehatch's Avatar
Default rpm dipping and idle bouncing
just replaced the thermostat (stuck open) and did the water pump (leaking) have cleaned bothe the iacv and throttle body
my idle will drop down and bounce back up seems like the car is almost dying when it dips. it doesn't start automatically usually after a little bit of driving
my heat gauge isn't working so I can't really tell if it's over heating no smoke coming from anywhere tho
any ideas helpful
Old 02-26-2015, 12:51 PM
billabongrob's Avatar
Default Re: rpm dipping and idle bouncing
Air in the system? I believe those symptoms can be caused by that. Did you properly bleed it after?
Old 02-26-2015, 09:59 PM
I'm pretty sure no air in the system because I ran with the cap off and no bubbles.
my top radiator hose expands. I am getting a new hose tomorrow to replace
I've heard it could be map sensor issues?
Ef4doorwagon
17
04-06-2014 03:31 PM
brownsEF
08-12-2009 04:34 PM
mfzbike
01-17-2009 05:03 PM
e30FTMFW
11-18-2008 11:52 AM
Offer
07-05-2006 08:39 AM
Quick Reply: rpm dipping and idle bouncing
