Reverse gear making noise????
Old 08-02-2008, 04:29 PM
C5teg's Avatar
Default Reverse gear making noise????
got a 98 integra gs. when put in reverse it make a weird whisling kinda noise.... kinda like it need new brake pad noise.... but only in reverse.....anyone got any idea what it is???
Old 08-02-2008, 04:56 PM
lmike6453's Avatar
Throw out bearing.
Old 08-02-2008, 05:13 PM
C5teg's Avatar
wat? explain? so does that mean i need a new tran??
C5teg's Avatar
so what i need to do??? can u explain
Old 08-02-2008, 05:23 PM
lmike6453's Avatar
Well if it doen't happen when the clutch is pressed down, then it's the tob. It has nothing to do with the internals of the transmission, but the tranny has to be removed to replace it.
Old 08-02-2008, 05:30 PM
C5teg's Avatar
Default Re: (lmike6453)
yeah it only happen in reverse......
Old 08-02-2008, 05:51 PM
PACT man's Avatar
Default Re: (C5teg)
is this when u are stopped or moving??? Honda's have a reverse whine when moving, thats normal/typical...
Old 08-02-2008, 08:32 PM
C5teg's Avatar
when u move...
Old 08-02-2008, 08:36 PM
Rickdrizzle's Avatar
isn't reverse supposed to make a different noise ?
Old 08-02-2008, 08:59 PM
JDM_CRX_PLEASE's Avatar
every honda/acura that ive driven, from integras to civics, CL, TL and RSX; all make a "whizzing" noise when u go in reverse.
Old 08-02-2008, 09:06 PM
Default Re: (JDM_CRX_PLEASE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">every honda/acura that ive driven, from integras to civics, CL, TL and RSX; all make a "whizzing" noise when u go in reverse.
My thoughts exactly.
Old 08-03-2008, 07:11 AM
C5teg's Avatar
well this is not the normal noise
Old 08-04-2008, 10:38 AM
raj_very's Avatar
Default Re: (C5teg)
i think it makes whizzzzzing noise. i think thats normal.
Old 08-04-2008, 10:51 AM
C5teg's Avatar
no it's a high pitch noise that's like it's time for brake pad but only in reverse
Old 08-04-2008, 11:31 AM
JDM_is_overrated's Avatar
Default Re: (C5teg)
yea kinda hard to tell what kind of noise it makes from just verbal description...
the reverse gear is loud in the first place, plus you dont use it that much
Old 08-04-2008, 01:44 PM
92b17a's Avatar
Default Re: Reverse gear making noise???? (C5teg)
have u checked the rear pads? If it is a high pitched noise in reverse it could be your rear brakes. The inner pads may be worn even if the outboard pads look ok. chances are if it is a throw out bearing it will happen in every gear wneh clutch is depressed.
De_tour
12
08-03-2007 05:55 PM
hybrider
11-23-2005 09:25 AM
david
11-07-2005 09:24 AM
spoon95eg
10-26-2005 04:43 PM
JDEM1
08-04-2003 08:24 PM
Quick Reply: Reverse gear making noise????
