HOW MUCH BOOST???
Old 05-05-2007, 08:41 AM
DC2HYB's Avatar
Default HOW MUCH BOOST???
OK SO HOW MUCH PSI. CAN I RUN ON A STOCK B20 VTEC?????
Old 05-05-2007, 09:13 AM
Rikter's Avatar
Hey Mr.7 post newb. Upper right in the red colour.. it's called SEARCH.
-Rik
Old 05-05-2007, 10:04 AM
VTECth1s's Avatar
Default Re: HOW MUCH BOOST??? (DC2HYB)
The psi/boost is not your main concern, its the size of the turbo your using first, that determines how much boost you can run. Everyone uses different size turbos which produces different amounts of boost. You can use a small mitsubishi turbo @ 15psi and put down around 210+ whp, or run a GT28R @ 15psi and put down around 280+ whp. Find out first which turbo you want to use, then you can determine or estimate how much boost you can run on your b20 block. Plus you may want to reinforce the b20 block since they have thin cylinder walls and will blow. I suggest sleeving it first and etc.
Old 05-05-2007, 10:37 AM
Ek Forever y0!
Libertariat's Avatar
Default Re: HOW MUCH BOOST??? (VTECth1s)
b20's have weak cylinder walls, you're definately going to need a good build before you can run any boost on it. Even then I wouldn't run more than 250whp.
Old 05-05-2007, 10:45 AM
VTECth1s's Avatar
to the OP, ditch the b20 block and get a b18c/1 block or do an Ls/v-t, it'll be more reliable then the b20v-t. Build the block first before the head, since the block will fail first. And with a turbo in the mix, additional heat will just decrease the life of the motor.
Old 05-05-2007, 03:18 PM
kshgl87's Avatar
agreed, either get a new block or do something sweet with the one you have
Old 05-05-2007, 07:10 PM
been there done that
doood's Avatar
Default Re: (kshgl87)
a b20 block is fine with boost. just depends on how much. detonation will kill the sleeves.
it's not because they are thin it's because of the way they are cast. k20 sleeves are thinner and hold up fine to boost.
Old 05-05-2007, 07:24 PM
Ek Forever y0!
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
it's not because they are thin it's because of the way they are cast. k20 sleeves are thinner and hold up fine to boost. </TD></TR></TABLE>
Nice to know.
Old 05-05-2007, 07:52 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECth1s &raquo;</TD></TR><TR><TD CLASS="quote">The psi/boost is not your main concern, its the size of the turbo your using first, that determines how much boost you can run. Everyone uses different size turbos which produces different amounts of boost. </TD></TR></TABLE>
i know what you're trying to say, but you could have worded it better. two different size turbo's will push different amounts of cfm and make different hp at the same boost level.
Old 05-05-2007, 08:28 PM
Hype-R Stalker
CleanLikeJdm's Avatar
I dunno why everyone is trying to be so informative ..
I would of just said a Lot.
Old 05-07-2007, 07:27 PM
DC2HYB's Avatar
THANX GUYS I APRETIATE ALL YOU THAT ARE TRYING TO HELP...
Old 05-07-2007, 08:55 PM
HT Black OPs
00IntegrAllmotoR's Avatar
A Lot ^^^^
Old 05-08-2007, 06:23 AM
vladd's Avatar
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">a b20 block is fine with boost. just depends on how much. detonation will kill the sleeves.
can't really compare the b20 with the k20; they're completely different engines. if i had a choice between turboing a b20 or b18b i'd go with the b18b.
Old 05-08-2007, 05:12 PM
doood's Avatar
Default Re: (vladd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd &raquo;</TD></TR><TR><TD CLASS="quote">can't really compare the b20 with the k20; they're completely different engines. if i had a choice between turboing a b20 or b18b i'd go with the b18b.</TD></TR></TABLE>
all im saying is people think b20 sleeves are weak because they're too thin. which is not the case.
hmtcrxsir
15
02-06-2009 08:01 PM
ILS_Thatstight
09-12-2006 06:42 PM
vtakef
04-20-2006 03:55 PM
GoCarInteg
11-13-2005 12:35 AM
MartGSR
10-15-2002 09:35 AM
Quick Reply: HOW MUCH BOOST???
